MQTT subscribes on UiFlow
@world101 Makes no difference here...
I can’t help much without knowing your setup. What are you seeing on the REPL or serial monitor? What devices and firmware version are you running? Post your code and I’ll see if I can figure out your issue.
@world101 Thanx! After making new topics and setting them to QoS=0, and retain=0, it finally works with many MQTT subscriptions on both M5Stack and M5Stick-C! (1.4.4 and 1.4.5)
(PS! Just changing the old topics that had retain back to no retain, did not work, had to make new ones.)
