    Power on and off with an external switch when panel mounted
    3 Posts 2 Posters 5.6k Views 1 Watching
      jnicol
      Hi Guys,
      I would like to panel mount a couple of the M5Stacks in an instrument cluster. I am trying to figure out how to power these on and off when I don't have access to the power button when it is behind the panel. I can run a usb cable to small UPS back-up battery (actually for a raspberry pi) and this feeds power to the M5Stacks. As soon as I turn on the UPS power switch, all is good that the M5's power on, but I have no way to turn them off. Is there a way to mount an external switch on the panel that will turn the M5's on and off without hacking into the mounted push-buttons?
      Also, just to add more info, the current buttons are used like this: The middle button selects the different sensor readings from the engine and the left and right buttons are used to change the brightness of the screen.
      Cheers
      John
        feed power to the bus connection inside the m5stack (2x15 pin connection) as long as no battery is connected then that should work as you need.
          jnicol
          Thanks for the info. Solves the issue. So looking at the schematic I would connect to pin 28 for 5V and pin 1,3 or 5 for GND.
          Cheers.
