    Connection problems
    General
    4.5k
    • M5StickFreaklerM
      M5StickFreakler
      Hi folks
      I have often a connection problem to my m5stack device.
      If I upload a program to the device and something goes wrong, I cannot connect to the device again.
      I have to close the Windows UIFlow and start up again and load code again.
      This problem occurs very often and it is very annoying.
      Software:
      • Firmware UIFlow-v1.4.5.1 (also with v1.4.5)
      • Windows UIFlow 1.0.8.1
      It seams to be a blocking of the com port by the Windows software because if I try to burn the firmware I get following message:
      Command:
      --chip esp32 --port COM4 --baud 921600 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 application_0x10000.bin 0x1000 bootloader_0x1000.bin 0x200000 fatfsImg_0x200000.img 0x8000 partitions_0x8000.bin 0xf000 phy_init_data_0xf000.bin 0x3ff000 wifi_0x3ff000.bin
      [3288] Failed to execute script esptool
        File "esptool.py", line 2849, in <module>
        File "esptool.py", line 2842, in _main
        File "esptool.py", line 2549, in main
        File "esptool.py", line 213, in __init__
        File "site-packages\serial\__init__.py", line 88, in serial_for_url
        File "site-packages\serial\serialwin32.py", line 62, in open
      serial.serialutil.SerialException: could not open port 'COM4': PermissionError(13, 'Access denied', None, 5)
      esptool.py v2.5.0
      After restarting the windows UIFlow everything works fine for a while.
      Does anyone have a better solution?
      Best regards
      Thomas
      • L
        Lewis-H
        Make Sure It's Actually Your Network Problem. ...
        Power Cycle Everything and Check Other Devices. ...
        Check Physical Connections. ...
        Run the Windows Network Troubleshooter. ...
        Check for a Valid IP Address. ...
        Try a Ping and Trace Its Route. ...
        Contact Your ISP. ...
        Wait the Network Problems Out.
