    KinoWheels M5Stack porting WIP...
    PROJECTS
    5
    13.1k
    • C
      cepics
      Hi All, this is my porting of KinoWheels to m5stack using espnow to play wireless with R0nin
      tested with:
      R0nin 1
      KinoWheels
      R0nin Forum
      TX: M5Stack + PROTO MODULE
      RX: M5Atom Lite + GROVE cable
      SOFTWARE:
      first we upload rx code to know the mac address on serial monitor
      in the arduino IDE select M5StickC board for ATOM
      #include "M5Atom.h"
      #include <esp_now.h>
      #include <WiFi.h>
      #define WIFI_CHANNEL 1
      uint8_t localCustomMac[] = {0x36, 0x33, 0x33, 0x33, 0x33, 0x33};
      const byte maxDataFrameSize = 200;
      // must match the controller struct
      struct __attribute__((packed)) DataStruct {
        int X;
        int Y;
        int Z;
      DataStruct myData;
      #define BAUDRATE 100000  // oder  100000 115200
      #define SERIALPORT Serial2  // - uncomment this line if using an arduino based board with more than one HW serial port
      class BMC_SBUS
        public:
          uint8_t sbusData[25];
          int16_t servos[18];
          void begin(void);
          void Servo(uint8_t ch, int16_t position);
          void Send(void);
          void Update(void);
        private:
          uint8_t byte_in_sbus;
          uint8_t bit_in_sbus;
          uint8_t ch;
          uint8_t bit_in_servo;
      void BMC_SBUS::begin()
        //intialise private data arrays
        //sbus_data is formatted for correct serial output
        //note that the actual 11bit sbus data for each channel is embedded across multiple data bytes in a very stange order
        //byte 1 and bytes 24 and 25 should be left as is
        //the first is a start byte, the last is a stop byte and the second last holds various flags
        //servos is the internal per channel position and is more straightforward - one int_16 per channel
        uint8_t loc_sbusData[25] = {0x0f, 0x01, 0x04, 0x20, 0x00, 0xff, 0x07, 0x40, 0x00, 0x02, 0x10, 0x80, 0x2c, 0x64, 0x21, 0x0b, 0x59, 0x08, 0x40, 0x00, 0x02, 0x10, 0x80, 0x00, 0x00};
        int16_t loc_servos[18]   = {1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 0, 0};
        //setup serial port to transmit at 100k baud and use 1 parity and 2 stop bits
        //               (baud-rate/protocol/RXpin/TXpin/INVERT)
          SERIALPORT.begin(BAUDRATE, SERIAL_8E2, 32, 26, true); // ATOM GROVE PORT
        //setup public data arrays
        memcpy(sbusData, loc_sbusData, 25);
        memcpy(servos, loc_servos, 18);
      void BMC_SBUS::Servo(uint8_t ch, int16_t position)
        //set servo position on single channel
        if ((ch > 0) && (ch <= 16))
          constrain (position, 0, 2048); //keep within min/max values
          servos[ch - 1] = position; //expects a non zero starting index to the channel
      void BMC_SBUS::Send(void)
        //send data over serial port
        SERIALPORT.write(sbusData, 25); //according to docs for Serial we can send the array along as is without a loop
      void BMC_SBUS::Update(void)
        //update positions for all servo channels within the SBUS data frame
        //ignores digital servos and any failsafe mode stuff that was originally written
        //clear out existing sbus data for all channel data bytes
        //ignores first and last bytes in the array (start and stop bytes)
        //mapping loop relies on initial 0 values - do not omit this step!
        uint8_t i;
        for (i = 1; i < 24; i++)
          sbusData[i] = 0;
        //reset counters
        ch = 0;
        bit_in_servo = 0;
        byte_in_sbus = 1;
        bit_in_sbus = 0;
        //format sbus data - maps sevo data array to sbus data array 1bit at a time
        //correctly deals with the little endian byte order in the process
        for (i = 0; i < 176; i++) //16channels*11bits = 176bits
          if (servos[ch] & (1 << bit_in_servo)) //bitwise AND to check if the correct servo databit is set to 1
            sbusData[byte_in_sbus] |= (1 << bit_in_sbus); //bitwise OR sets the correct sbus databit if true
          //increment bit counters
          bit_in_sbus++;
          bit_in_servo++;
          //if end of sbus byte reset sbus bit counter and increment sbus byte counter
          if (bit_in_sbus == 8)
            bit_in_sbus = 0;
            byte_in_sbus++;
          // if we have reached bit 11 in the servo data increment channel index and reset servo bit counter
          if (bit_in_servo == 11)
            bit_in_servo = 0;
            ch++;
      //Declare BMC_SBUS Object
      BMC_SBUS mySBUS;
      // Sbus delay value
      const int sbusWAIT = 7;      //frame timing delay in msecs
      // Declare sbus control channels
      int panChannel = 1;
      int tiltChannel = 2;
      int rollChannel = 4;
      int sentX;
      int sentY;
      int sentZ;
        /*                      Void setup                           *
        //  M5.begin();
        M5.begin(true, false, true);
        Serial.begin(115200);
        delay(200);
        Serial.print("\r\n\r\n");
        WiFi.mode(WIFI_AP);
        Serial.println( WiFi.softAPmacAddress() );
        WiFi.disconnect();
        if (esp_now_init() == ESP_OK)
          Serial.println("ESPNow Init Success!");
        else
          Serial.println("ESPNow Init Failed....");
        esp_now_register_recv_cb(OnDataRecv);
        sentX = 1023;
        sentY = 1023;
        sentZ = 1023;
        // Start BMC_SBUS object
        mySBUS.begin();
        /*                      Void Loop                           *
        sentX = (myData.X);
        sentY = (myData.Y);
        sentZ = (myData.Z);
      //  Serial.print("sentX ");
      //  Serial.println(sentX);
      //  Serial.print("sentY ");
      //  Serial.println(sentY);
      //  Serial.print("sentZ ");
      //  Serial.println(sentZ);
        for (int i = 0; i < 1; i++) {   //SBUS needs data every 7 Milliseconds. I repeat it three times for some time to pass for calculating speeds.
          mySBUS.Servo(panChannel, sentX);
          mySBUS.Servo(tiltChannel, sentY);
          mySBUS.Servo(rollChannel, sentZ);
          // Update SBUS object and send data
          mySBUS.Update();
          mySBUS.Send();
          delay(sbusWAIT);
        if (M5.Btn.wasPressed())
        M5.update();
      void OnDataRecv(const uint8_t *mac_addr, const uint8_t *incomingData, int data_len)
        memcpy(&myData, incomingData, sizeof(myData));
        Serial.print ("MAC ADDRES = ");
        for (byte n = 0; n < 6; n++) {
          Serial.print (mac_addr[n], HEX);
        stato ++;
        Serial.println ();
      open arduino serial monitor and pick the receiver MAC ADDRESS.
      put the receiver MAC ADDRESS, in the TX code instead of "XX"
      #include <M5Stack.h>
      #include <ESP32Encoder.h>
      ESP32Encoder encoderX;
      ESP32Encoder encoderY;
      ////////////////////ESPNOW/////////////////////////
      #include <WiFi.h>
      esp_now_peer_info_t slave;
      // RX MAC ADDRESS HERE
      uint8_t remoteMac[] = {0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX};
      const uint8_t maxDataFrameSize = 200;
        int X;
        int Y;
        int Z;
      DataStruct myData;
      const esp_now_peer_info_t *peer = &slave;
      uint8_t dataToSend[maxDataFrameSize];
      unsigned long lastSentMillis;
      unsigned long sendIntervalMillis = 10;
      unsigned long sentMicros;
      unsigned long ackMicros;
      ///////////////////////////FINE ESPNOW///////////////
      int xStampEnd = 0, yStampEnd = 0, timeStampEnd = 0;
      int xPassed, yPassed, timePassed;
      int X = 1023, Y = 1023, Z = 1023;
      int pulsesX, pulsesY;
      int  potiX = 100,  potiY = 100;
      byte gearX = 2;
      byte gearY = 2;
      bool toggleZ;
      bool toggleUSD;
      //bool StatoRX;
        M5.Lcd.clear(BLACK);
        M5.Lcd.fillRoundRect(5, 10, 310, 150, 10, TFT_BLACK);
        M5.Lcd.fillRoundRect(15, 20, 290, 130, 5, TFT_YELLOW);
        M5.Lcd.fillRoundRect(25, 30, 270, 110, 55, TFT_BLACK);
        M5.Lcd.fillRoundRect(5, 150, 310, 90, 10, TFT_BLACK);
        M5.Lcd.fillRoundRect(15, 160, 290, 70, 5, TFT_YELLOW);
        M5.Lcd.fillRoundRect(25, 170, 270, 50, 25, TFT_BLACK);
        M5.Lcd.setTextColor(RED);
        M5.Lcd.setTextSize(5);
        M5.Lcd.setCursor(80, 60);
        M5.Lcd.println("RONIN");
        M5.Lcd.setTextColor(YELLOW);
        M5.Lcd.setCursor(55, 180);
        M5.Lcd.println("P");
        M5.Lcd.setCursor(245, 180);
        M5.Lcd.println("T");
        M5.update();
        WiFi.mode(WIFI_STA);
        WiFi.disconnect();
          Serial.println("ESP NOW INIT!");
        else
          Serial.println("ESP NOW INIT FAILED....");
        memcpy( &slave.peer_addr, &remoteMac, 6 );
        slave.channel = WIFI_CHANNEL;
        slave.encrypt = 0;
        if ( esp_now_add_peer(peer) == ESP_OK)
          Serial.println("Added Peer!");
          Serial.println();
        esp_now_register_send_cb(OnDataSent);
        // clear the encoder's raw count and set the tracked count to zero
        encoderX.clearCount();
        encoderY.clearCount();
        // Attache pins for use as encoder pins
        encoderX.attachHalfQuad(2, 3);
        encoderY.attachHalfQuad(34, 35);
        Serial.println("<ready>");
        M5.update();
        ariloop();
        M5.update();
        sendData();
        Serial.print("x");
        Serial.print(pulsesX);
        Serial.print("y");
        Serial.print(pulsesY);
        Serial.println("end");
        delay(20); // PROVARE A TOGLIERLA
      void ariloop() {
        pulsesX = encoderX.getCount();
        pulsesY = encoderY.getCount();
        timePassed = millis() - timeStampEnd;
        xPassed = xStampEnd - pulsesX;
        yPassed = pulsesY - yStampEnd;
        if (M5.BtnC.wasReleased()) {
          gearY ++;
          if (gearY == 4) {
            gearY = 1;
          if (toggleUSD) {
            M5.Lcd.setCursor(140, 180);
            M5.Lcd.println("UP");
          M5.Lcd.setCursor(105, 180);
          M5.Lcd.println(gearX);
          M5.Lcd.setCursor(205, 180);
          M5.Lcd.setCursor(255, 180);
          M5.Lcd.println(gearY);
          delay(200);
        } else if (M5.BtnB.wasReleased()) {
          toggleZ = !toggleZ;
          if (toggleZ) {
            M5.Lcd.println("(");
            M5.Lcd.setCursor(120, 180);
            M5.Lcd.println("ROLL");
            M5.Lcd.println(")");
          } else {
            if (toggleUSD) {
            delay(200);
          delay(200);
        } else if (M5.BtnA.wasReleased()) {
          gearX ++;
          if (gearX == 4) {
            gearX = 1;
          if (toggleUSD) {
          delay(200);
        } else if (M5.BtnB.wasReleasefor(700)) {
          toggleUSD = !toggleUSD;
          if (toggleUSD) {
            delay(200);
          } else {
            delay(200);
        if (M5.BtnA.isPressed() && toggleZ) {
          Z = 723;   //823, 1023, 1223
          delay(100);
        }   else if (M5.BtnC.isPressed() && toggleZ) {
          Z = 1323;//823, 1023, 1223
          delay(100);
        } else {
          Z = 1023;  //823, 1023, 1223
        if (gearX == 1) {
          potiX = 100;
        if (gearX == 2) {
          potiX = 200;
        if (gearX == 3) {
          potiX = 300;
        if (gearY == 1) {
          potiY = 100;
        if (gearY == 2) {
          potiY = 200;
        if (gearY == 3) {
          potiY = 300;
        if (toggleUSD) {
          // GRAFICA UPSIDEDOWN
          potiX = potiX * - 1;
          potiY = potiY * - 1;
        } else {
          // GRAFICA DRITTA
        X = 1023 + potiX * xPassed / timePassed;
        Y = 1023 + potiY * yPassed / timePassed;
        xStampEnd = pulsesX;
        yStampEnd = pulsesY;
        timeStampEnd = millis();
      void sendData() {
        if (millis() - lastSentMillis >= sendIntervalMillis) {
          lastSentMillis += sendIntervalMillis;
          myData.X = X;
          myData.Y = Y;
          myData.Z = Z;
          uint8_t bs[sizeof(myData)];
          memcpy(bs, &myData, sizeof(myData));
          sentMicros = micros();
          esp_now_send(NULL, bs, sizeof(myData)); // NULL means send to all peers
          Serial.println("  sent data");
          Serial.println();
      void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status)
        if (status == ESP_NOW_SEND_SUCCESS) {
          Serial.println("RX ACCESO");
          M5.Lcd.fillCircle(60, 60, 10, TFT_GREEN);
          //    StatoRX = 1;
        } else {
          Serial.println("RX SPENTO");
          M5.Lcd.fillCircle(60, 60, 10, TFT_RED);
          //    StatoRX = 0;
        Serial.println();
      HARDWARE
      encoders wiring on M5Stack is a bit different of original kinowheels (arduino mega) one.
      with esp32 based board you can invert ttl signal in serial.begin declaration... so no need to add a serial inverter IC for D-Bus, so ATOM GROVE cable go straight to R0nin D-Bus
      GROVE ------ D-BUS
      GRD ---------- Black
      5V ------------ Red
      TX ------------ White
      RX ------------- Yellow (not connected on R0nin1) to test on R0nin2
      this is the code to use M5Stack kinowheels in the simulator:
      float pulsesX, pulsesY;
        M5.Lcd.setCursor(130, 40);
        M5.Lcd.println("PC");
        M5.update();
        Serial.print("x");
        Serial.print("y");
        delay(20);
      I want to use this case in the future...
      NaKino
      • C
        cepics
        RESERVED
        • F
          fonzie @cepics
          @cepics
          Do you have a photo of the wiring? I don't understand the wiring diagram well. Thank you.
          • G
            gunnar lindner
            • StarLogS
              StarLog
              Has anyone gotten this setup to work. Having issues with the Mac address setup, need help.
