    [Solved] 5 RELAY Units on M5Stack device
    General
    5.5k
    • M5StickFreaklerM
      M5StickFreakler
      Hi folks
      I have played around a bit with some relay units, but I cant find a way to connect 5 units to my M5Stack unit.
      I have tried:
      • to connect them all to same port via splitters
      • to connect them all via Pa.HUB-Unit
      • to connect them all via Pb.HUB-Unit
      It does not work.
      Does anyone have an idea or has everyone done it?
      Thanks very much
      Thomas
      • C
        crami25
        @M5StickFreakler
        You have to use the Pb-Hub unit, black connector of the relay units to the black connectors of the Pb-Hub (for analog and/or digital input/outputs, e.g. realys) . The Pa-Hub is used connecting i2c units (red connectors) with the same i2c address (e.g. to environment units).
        You can programm the 6 channels (analog or digital, equivalent to multiple Core-B channels) of the Pb-hub using blockly.
        good luck crami25
        M5StickFreaklerM 1 Reply Last reply Reply Quote 1
        • M5StickFreaklerM
          M5StickFreakler @crami25
          @crami25
          Thank you crami25
          I thought that I have to use the RELAY-Unit-Component and the PbHub.Unit-Component simultaneously in UIFlow.
          But as you told me, I just have to set the Outputs on the PbHub to 0 oder 1 :-)
          No need of the RELAY-Unit-Component in software.
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import unit
          setScreenColor(0x222222)
          pbhub0 = unit.get(unit.PBHUB, unit.PORTA)
          while True:
            pbhub0.digitalWrite(0, 0, 1)
            wait_ms(100)
            pbhub0.digitalWrite(1, 0, 1)
            wait_ms(100)
            pbhub0.digitalWrite(2, 0, 1)
            wait_ms(100)
            pbhub0.digitalWrite(3, 0, 1)
            wait_ms(100)
            pbhub0.digitalWrite(4, 0, 1)
            wait(1)
            pbhub0.digitalWrite(0, 0, 0)
            wait_ms(100)
            pbhub0.digitalWrite(1, 0, 0)
            wait_ms(100)
            pbhub0.digitalWrite(2, 0, 0)
            wait_ms(100)
            pbhub0.digitalWrite(3, 0, 0)
            wait_ms(100)
            pbhub0.digitalWrite(4, 0, 0)
            wait(1)
          Great it works!
          Best regards Thomas
