How to connect ToF sensor to ProtoHat
I have a ToF sensor that has pin configured in this way Vin Gnd SCL SDA, I want to use it in Proto HAT module the problem is that, sensor's pins aren't symmetrical to HAT boards pin configurations and don't matches (and spaces to operate isn't too much). See the picture.
What you suggest? -
HI @AndreaF the space is a little tight, but perhaps you can put it in sideways and solder things to the right place via a few extra wires. As you can see in the picture of env hat below, the SDA of your TOF module should be connected to pin G0 and the SCL should be connected to G26
