    Env vs Hat Env
    9 Posts 3 Posters 20.3k Views 1 Watching
    • OyczEO Offline
      OyczE
      Hey all,
      finally i have some time to play with Env Hat, at first time there was some strange readings +-5% diff then normal env.
      Now there was time to check this out and here it is:
      text alternatywny
      and HW inside:
      text alternatywny
      HW info:
      M5StickC ENV Hat (DHT12, BMP280, BMM150)
      ENV Unit with Temperature Humidity Pressure Sensor (DHT12+BMP280)
      Inside ENV Hat we have DHT12 without blue case du the size, but why there is so big difference between normal Env ?
      Any clue ?
      Just BTW i have 3 Env Hat and all works in same way.
      Regards
        dda
        If you have the OLED and WiFi on, the heat they produce will skew the results. I connect the ENV hat to my Stick C with wires, and I get different, lower-temp results.
        • OyczEO Offline
          OyczE
          Ok let me try it. So the whole clue of env hat should come with some kind of shield to eliminate heat from stick.
          • OyczEO Offline
            OyczE @dda
            @dda said in Env vs Hat Env:
            So after test with extra cables all is ok when hat is moved out from stick.
            But this is a main clue of hat to stick it in to StickC without extra lobg cable.
            @lukasmaximus please comment this, for me this looks like design issue.
            • G Offline
              grlind @OyczE
              @mati
              Can you tell me how to compile the code I am confused on how to bring the code into the Arduino IDE.
              I created a main sketch and then copied the code into Mstickc_ENVHat, I also created 4 tabs.. DHT12.cpp, DHT12.h, and bmm150.cpp, and bmm150.h, and bmm150_defs.h...
              I get errors
              C:\Users\AppData\Local\Temp\arduino_build_90317\sketch\MstickC_ENVhat.ino.cpp.o:(.literal._Z4loopv+0x34): undefined reference to `DHT12::readTemperature(unsigned char)'
              C:\Users\AppData\Local\Temp\arduino_build_90317\sketch\MstickC_ENVhat.ino.cpp.o:(.literal._Z4loopv+0x38): undefined reference to `DHT12::readHumidity()'
              • OyczEO Offline
                OyczE @grlind
                @grlind well its simple UIFlow drag and drop showcase.
                I will try to do same in arduino today.
                  dda @OyczE
                  @mati I have mentioned this to Jimmi, and his answer basically was, well don't use wifi and OLED. Not exactly a practical answer. I'd rather have a long hat, isolating the DHT and BMP from the heat.
                  • OyczEO Offline
                    OyczE @dda
                    rlly ?! hmm what's the point of making HAT with req extra cable to unHAT it :D
                    ok let's end this topic as a lesson. thx @dda for info.
                    • G Offline
                      grlind
                      @grlind I was able to get to work in Ardunio I just combine the DHT into the main sketch all things good though the pressure reading are off... I owuld like to see the uflow - I have not done anything in uflow want to try it.. Is your code posted somewhere?
