    Windows M5Burner Proxy support
    General
    7
    17.4k
    • OyczEO
      OyczE
      Hey !
      Please consider to add proxy support inside burner. Now we 1.0.0 version with Settings tab, maybe in future rls we can find there
      Use network proxy Yes
      IP / port / type of auth
      Regards
      Mati
      • lukasmaximusL
        Hi @Mati thanks for your suggestion. Do I understand correctly that you wish to have a feature where the user can define their own proxy server to host their own firmwares?
        • OyczEO
          OyczE
          @lukasmaximus said in Windows M5Burner Proxy support:
          Hi Lukas,
          well here is full story:
          At work on my corporate PC whole network traffic req connection via proxy. So with internet browser its easy just go to option and setup a proxy and go.
          In M5 Burner we can't do this. First run of Burner req a downloading a proper SW packages for example Beta UIFlow etc. This step will fail without proxy setup inside Burner.
          If there is still some questions let me know.
          Regards
          • lukasmaximusL
            Hi @Mati Sorry to hear about your situation, I have forwarded this issue on to the development team. Meanwhile if you are familiar with esptool you can use it to flash the latest firmware which can be found here: https://github.com/EeeeBin/UIFlow-Firmware/tree/beta
            • OyczEO
              OyczE @lukasmaximus
              @lukasmaximus well this is a issue only in proxy restricted networks. So its non critical or blocker.
              Its could be add to considering in next MBurner sprint.
              Thx for reply Lukas
              • L
                liushasha
                @mati said in Windows M5Burner Proxy support:
                proxy
                Its not easy to add a Proxy support, in this situation you can try to download easy loader on the documentation page.
                  ajb2k3 @OyczE
                  Thx for reply Lukas
                  A proxy restriction network? Would installing a VPN service not be better?
