    Use Pa.hub with Uiflow
    UIFlow
    3.6k
    • D
      davidiot
      Hello everyone!
      I bought a Pa.hub. I would like to use it with Uiflow.
      I tested with Extend i / o on channel 0 of Pa.hub but did not work. The Extend i / o is not visible by the M5Stick-c.
      Someone will have an example code in Uiflow?
      Thank you
        I do have demo micropython code for that found here
        PaHub Code Demo
        It was built using UIFlows blocks but alas I didn't save the file :(
        BTW you have to initialise the i2c port before accessing it.
        I don't think the Stick C can power it which I think is the reason that it is disabled in UIFLow.
