šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    Do you have any faces keyboard programs?
    FACES Kit
    10
    17.6k
    • sysdl132S
      sysdl132
      Hello!
      I need a faces keyboard program!
      Do you have it?Thanks!
      For Atom:115200/230400/921600
      • lukasmaximusL
        Could you be more specific? what faces keyboard program? If your talking about the factory stock firmware you can find it here https://github.com/m5stack/FACES-Firmware
        sysdl132S 2 Replies Last reply Reply Quote 0
        • sysdl132S
          sysdl132 @lukasmaximus
          @lukasmaximus thanks
          • sysdl132S
            @lukasmaximus uhh..."'DDRB' was not declared in this scope!"
            • lukasmaximusL
              Did you get this message during the flashing process? What method did you use to flash the firmware? The M5Stack must be completely erased before flashing this firmware
                mihazi
                i got this message too. on compilation phase. Arduino IDE. It was updated to 1.8.10. I choose M5Stack-Core-ESP32 board.
                  ā€œNot declared in this scopeā€ usually means that it can’t find a library installed on your computer. Make sure that you have all the libraries listed in the top list.
                  • lukasmaximusL
                    If you can share your code, it would be much easier for us to help resolve the problem. What exactly are you trying to do with the keyboard face?
                      mihazi @lukasmaximus
                      @lukasmaximus
                      I took GameBoy.ino file from https://github.com/m5stack/FACES-Firmware, Install ArduinoIDE from official site and setup esp32 support. Sketch file is original, not modified.
                      And now, I get error, as start compile there. here is full text:
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino: In function 'void setup()':
                      GameBoy:16:3: error: 'DDRC' was not declared in this scope
                         DDRC = 0x01;
                      GameBoy:17:3: error: 'PORTC' was not declared in this scope
                         PORTC = 0x01;
                      GameBoy:18:3: error: 'DDRD' was not declared in this scope
                         DDRD = 0x00;
                      GameBoy:19:3: error: 'PORTD' was not declared in this scope
                         PORTD = 0x00;
                      GameBoy:20:3: error: 'DDRB' was not declared in this scope
                         DDRB = 0x00;
                      GameBoy:21:3: error: 'PORTB' was not declared in this scope
                         PORTB = 0xff;
                      GameBoy:22:11: error: 'PINB' was not declared in this scope
                         oldPINB=PINB;
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino: In function 'void requestEvent()':
                      GameBoy:30:14: error: 'PINB' was not declared in this scope
                         Wire.write(PINB);
                      GameBoy:10:23: error: 'PORTC' was not declared in this scope
                       #define IRQ_1 Set_Bit(PORTC,0)
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino:5:32: note: in definition of macro 'Set_Bit'
                       #define Set_Bit(val, bitn)    (val |=(1<<(bitn)))
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino:34:5: note: in expansion of macro 'IRQ_1'
                           IRQ_1;
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino: In function 'void loop()':
                      GameBoy:40:6: error: 'PINB' was not declared in this scope
                         if(PINB!=oldPINB)
                      GameBoy:11:23: error: 'PORTC' was not declared in this scope
                       #define IRQ_0 Clr_Bit(PORTC,0)
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino:6:33: note: in definition of macro 'Clr_Bit'
                       #define Clr_Bit(val, bitn)     (val&=~(1<<(bitn)))
                      C:\Users\userrrr\Downloads\FACES-Firmware-master\FACES-Firmware-master\GameBoy\GameBoy.ino:44:5: note: in expansion of macro 'IRQ_0'
                           IRQ_0;
                      exit status 1
                      and here ino file
                      #include <Wire.h>
                      #define FACES_KEYBOARD_I2C_ADDR 0x08
                      #define Get_Bit(val, bitn)    (val &(1<<(bitn)) )
                      //KEY PORTB
                      //IRQ PC0
                      unsigned char oldPINB=0;
                      void setup()
                        DDRC = 0x01;
                        PORTC = 0x01;
                        DDRD = 0x00;
                        PORTD = 0x00;
                        DDRB = 0x00;
                        PORTB = 0xff;
                        oldPINB=PINB;
                        Wire.begin(FACES_KEYBOARD_I2C_ADDR);
                        Wire.onRequest(requestEvent);
                      unsigned char i = 0;
                      unsigned char temp = 0, hadPressed = 0;
                      void requestEvent()
                        Wire.write(PINB);
                        if (hadPressed == 1)
                          hadPressed = 0;
                          IRQ_1;
                      void loop()
                        if(PINB!=oldPINB)
                          temp=PINB;
                          oldPINB=temp;
                          IRQ_0;
                          hadPressed = 1;
                        if (PINB != 0xff)
                          switch(PINB)
                            case 0xFE:temp='U';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0xFD:temp='D';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0xFB:temp='L';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0xF7:temp='R';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0xEF:temp='A';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0xDF:temp='B';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0xBF:temp='s';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                            case 0x7F:temp='S';while(PINB!=0xff)delay(1);IRQ_0;hadPressed = 1;break;
                        delay(10);
                        mihazi
                        Problem solved. Apparently this skethes only for faces-modules, not for Core-module.
                        You should be more specific in progrmamm description. Whatever, thanks for answer.
