    LCDVOL ?
    UIFlow
    8
    15.3k
    • G
      gadjet
      What does LCDVOL do? I assume change the LCD voltage? I've tried various values, 1 switches off the backlight but not sure what other values are supposed to do?
      I've searched but found nothing is there any documentation on this?
      Thanks.
      • lukasmaximusL
        Hi Gadjet with the lcdvol block you can adjust the brightness of the lcd and also turn it off
          lcdvol block?
          • lukasmaximusL
            @ajb2k3 yeah its only available for the stick on uiflow, in the hardwares section under AXP
              Ah thanks
              • G
                gadjet
                Thanks but is there any documentation on what values do what?
                  ajb2k3 @gadjet
                  @gadjet not that I know off.
                  Please note that it is NOT LCDVOL that is a mislabel.
                  the function is actually LDO Voltage!
                  • H
                    heybin
                    lcdvol to control lcd voltage, must than 3V
