    Rotate UI object
    UIFlow
    6.8k
    • B
      brett
      Is it possible to rotate a UI object to a set angle?
        ajb2k3 @brett
        @brett with the 1.3.2 branch of UIFlow there is now the option to set a GUI object rotation angle.
        • B
          brett @ajb2k3
          @ajb2k3 I see an option to rotate a polygon under LCD.polygon, but I'm not seeing a GUI object rotation angle. Could you explain further?
            ajb2k3 @brett
            @brett said in Rotate UI object:
            When you add a label from the five icons above the Virtual M5Stack, a rotation block will appear in the UI Drop down menu.
            • lukasmaximusL
              @brett do you want to rotate the whole display or simply some of the graphic elements? As @ajb2k3 stated the rotation option is available for the text label, but elements such as the rectangle or triangle graphic elements are not rotatable due to the module they are based on not supporting this feature.
