    [Solved]Driving a single servo
    7 Posts 3 Posters 14.2k Views 1 Watching
      JimW
      using the M5 with firmware 1.2.3en and arduino 1.8.9
      I know you can't use servo.h, so I came up with a work around, or at least I thought I did.
      I cannot have M5.begin(); in the code or the servo doesn't work, without that the servo works but I cannot write to display.
      Is there a solution? here's the example code;
      #include <M5Stack.h>
      #define servoPin 5
      int i = 0;
      int servoPulse(int angle) {
      int pulseWidth = map(angle, 0, 180, 544, 2400);
      return pulseWidth;
      m5.begin();
      Serial.begin(9600);
      pinMode(servoPin, OUTPUT);
      for (int i=0; i<=180; i++) { // drive servo from 0 to 180 at max response
      int pulseWidth = servoPulse(i);
      //digitalWrite(servoPin, HIGH);
      delayMicroseconds(pulseWidth);
      //digitalWrite(servoPin, LOW);
      delayMicroseconds(20000 - pulseWidth);
      Serial.print(i);
      for (int i=180; i>=0; i--) { // return to 0 at half speed
      // delayMicroseconds(20000 - pulseWidth);
      delay(50);
      Serial.print(i);
        salty_good
        Hi, Please try to comment out this line -> Serial.begin(9600);
        Thank you!
          salty_good
          (Already set to serial speed 115200 in M5.begin () function)
            JimW
            I was hoping that it would be that simple, however, that wasn't the solution.
            I cannot use M5.Lcd.print and the servo at the same time.
              What device are you using?
              I use G21 which is also SDA on port A
                JimW
                I'm using an M5stack Core with the accelerometer built in, and arduino 1.8.9
                This problem occurs when using M5.begin(); which I apparently need to print to lcd inside the loop.
                So for instance, inside the loop,
                M5.Lcd.setCursor(0, 200);
                M5.lcd.setTextColor(WHITE,BLACK);
                M5.Lcd.print (i);
                The Servo will not work, but instead chatter.
                // M5.begin(); servo works but the display does not (this statement is inside the setup, for example,
                //myservo.attach(servoPin);
                  salty_good @JimW
                  @jimw Please try this code.
                  Serial speed 115200
                  and the firmware (1.2.3-en) for micropython
                  It is not for Arduino.
                  int servoPin = 5;
                  void servoSet(int Angle, int Time) {
                    int pulseWidth;
                    int TimeCount;
                    TimeCount = Time / 20;
                    for (int i = 0; i <= TimeCount; i++) {
                      pulseWidth = map(Angle, 0, 180, 544, 2400);
                    M5.Lcd.printf("M5Stack Servo test:\n");
                    M5.Lcd.printf("Angle 45deg\n");
                    Serial.println("Angle 45deg");
                    servoSet(45, 1000); //45deg
                    M5.Lcd.printf("Angle 135deg\n");
                    Serial.println("Angle 135deg");
                    servoSet(135, 1000); //135deg
