    fatal error: pgmspace.h: No such file or directory
    9.0k
    • Z
      zackng97
      Arduino: 1.8.7 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
      C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10807 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_108441 -warnings=none -build-cache C:\Users\USER\AppData\Local\Temp\arduino_cache_620437 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master\examples\Basics\Button\Button.ino
      C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10807 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_108441 -warnings=none -build-cache C:\Users\USER\AppData\Local\Temp\arduino_cache_620437 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master\examples\Basics\Button\Button.ino
      Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
      Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
      Detecting libraries used...
      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\USER\AppData\Local\Temp\arduino_build_108441\sketch\Button.ino.cpp" -o nul
      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_108441\sketch\Button.ino.cpp" -o nul
      Error while detecting libraries included by C:\Users\USER\AppData\Local\Temp\arduino_build_108441\sketch\Button.ino.cpp
      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master\src\Fonts\Font16.c" -o nul
      C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master\src\Fonts\Font16.c:3:22: fatal error: pgmspace.h: No such file or directory
      compilation terminated.
      Using library M5Stack-master at version 0.2.5 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\M5Stack-master
      exit status 1
      Error compiling for board Arduino Pro or Pro Mini.
      How to fix this problem? Please help thank you
      • lukasmaximusL
        @zackng97 said in fatal error: pgmspace.h: No such file or directory:
        In your error log it says you are compiling for arduino pro "Error compiling for board Arduino Pro or Pro Mini." I imagine since your on the m5stack forums that you are not trying to program an arduino board. The m5stack board definitions and libraries need to be installed first and then the m5stack device selected in the board list and also the port must be correct. please see this video on how to get started with m5stack in the arduino ide https://www.youtube.com/watch?v=U2es-l4z2Zg
