    NCIR unit weird values
    General
    5
    4.2k
    • T
      tialm
      Hi guys!
      So I got a m5stack with a ncir unit. I am using uiflow to test and I am getting temperature values all over the place... I was supposed to get 4ºC+- on my fridge and it says is -10ºC !! Other measures are also not consistent....
      Is there any way to reset the ncir unit or something like that? Or is it possible that it is faulty? Do your units give consistent results?
      Thank you!
      • G
        gothicmaestro @tialm
        @tialm I also always have wrong temperature values
        • H holofloh referenced this topic on
        • H
          holofloh @gothicmaestro
          @gothicmaestro
          see here: https://community.m5stack.com/topic/8081/emissivity-value-required
          • H
            harrietteytlxv222
            Same problem with me :( Did you fix it?
            https://vegasnowcasino-au.net/
            • H
              holofloh @harrietteytlxv222
              @harrietteytlxv222 did you read my post from Feb 12 (follow the link)? Do you use the appropriate emissivity value for your surface?
