    Help needed: M5Stack Dial VFD controller (relay start/stop + 0–10V speed)
    2 Posts 2 Posters 918 Views
    • G Offline
      gizmologic
      Hey everyone — I’m building a VFD controller using an M5Stack Dial (ESP32-S3) and I’m looking for help/advice from anyone who’s done something similar.
      Goal:
      Use the Dial screen/knob UI to control VFD speed via 0–10V
      Use a relay output for Run/Stop (or FWD/REV if possible)
      Clean, reliable wiring and code (industrial-ish setup)
      Hardware I’m using / planning:
      External 0–10V output module (DAC module or converter board)
      Relay module / isolated output to drive VFD digital input(s)
      Common 24V control cabinet environment (if needed)
      What I need help with:
      Best/most reliable way to generate 0–10V from ESP32 (recommended module/wiring)
      Proper isolation/grounding between ESP32, DAC, and VFD analog input
      Example code (Arduino or MicroPython) for knob → voltage output + button/relay logic
      UI ideas for the Dial (speed %, Hz, RPM, presets, accel/decel)
      If anyone has a wiring diagram, known-good DAC module, sample code, or tips, I’d really appreciate it!
      • robskiR Offline
        robski @gizmologic
        @gizmologic so in short words what you need is convert m5dial encoder to 0-10v signal and operate exernal relay with screen button right? what is your code so far?
