    195 Posts 79 Posters 580.4k Views 13 Watching
      thecuri
      I recently los all my private cloud projects....is there a way to get them back from your servers?
      • Z Offline
        zhumingqi
        I used UIFlow2 to devleop a simple UI demo, and I monitor the free memory with gc.mem_free(). I found the free memory reduced continiously though I called gc.collect() every loop. Finally, the UI can not update again, but the loop still was running.
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zhumingqi @zhumingqi
          I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
          • Z Offline
            zhumingqi
            Today, I updated the UIFlow to V2.3.4, and burned V2.3.4 firmware as well. Then I tested that image component again with M5GFX in UIFlow 2.3.4. But the issue still exists. After I switch two JPG pics with one image component for sometime, the memory will reduced continiously. Finally, the system will break out. And I try to use gc.collect() after every drawImage(), but it's not useful.
            Here is my design and python code:
            import os, sys, io, gc
            import M5
            from M5 import *
            ImageSwitchFlag = None
            def GcCollectAndPrint():
            global ImageSwitchFlag
            gc.collect()
            print(gc.mem_free())
            pass
            def btnA_wasClicked_event(state):
            if ImageSwitchFlag == 0:
            M5.Lcd.drawImage("/flash/res/img/RotaryBGBacklight.jpg", 0, 0)
            GcCollectAndPrint()
            ImageSwitchFlag = 1
            elif ImageSwitchFlag == 1:
            M5.Lcd.drawImage("/flash/res/img/RotaryBGBT.jpg", 0, 0)
            GcCollectAndPrint()
            ImageSwitchFlag = 0
            def setup():
            M5.begin()
            Widgets.fillScreen(0x000000)
            BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
            ImageSwitchFlag = 0
            def loop():
            M5.update()
            if name == 'main':
            try:
            setup()
            while True:
            loop()
            try:
            print_error_msg(e)
            except ImportError:
            print("please update to latest firmware")******
              Schwibach
              I wrote in another thread about my Sync... 0% problem.
              I am pretty sure now that it is a bug. I does not matter which program I use. I can run them from UIFlow 2.0. But as soon as I download a program, I will get the Sync... 0%
              Also, if I burn firmware without selecting startup, it will not even connect to UIFlow 2.0.
              I would really appreciate any guidance you could give.
              • O Offline
                otosan-maker
                I have found a bug in MQTT software. When I subscrive to a topic, the python code creates the subscription at the beggining of the setup code, before it connects to wifi and mqtt.
                Here is the sample:
                def setup():
                global page0, label0, LTemp, label1, temperatura, slider0, button0, off, mqtt_client, wlan, rotary
                mqtt_client.subscribe('termostato/temperatura', mqtt_termostato_temperatura_event, qos=0)
                M5.begin()
                m5ui.init()
                page0 = m5ui.M5Page(bg_c=0xffffff)
                label0 = m5ui.M5Label("Umbral", x=30, y=81, text_c=0x85231b, bg_c=0x302c2c, bg_opa=0, font=lv.font_montserrat_24, parent=page0)
                LTemp = m5ui.M5Label("Temperatura:", x=41, y=39, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
                label1 = m5ui.M5Label("19,0", x=152, y=81, text_c=0x85231b, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_24, parent=page0)
                temperatura = m5ui.M5Label("00.00", x=141, y=39, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
                slider0 = m5ui.M5Slider(x=38, y=119, w=160, h=22, mode=lv.slider.MODE.NORMAL, min_value=190, max_value=290, value=210, bg_c=0x115e9f, color=0x2c90e4, parent=page0)
                button0 = m5ui.M5Button(text="Set", x=54, y=172, bg_c=0x2196f3, text_c=0xffffff, font=lv.font_montserrat_14, parent=page0)
                off = m5ui.M5Button(text="OFF", x=124, y=171, bg_c=0xf36021, text_c=0xffffff, font=lv.font_montserrat_14, parent=page0)
                off.add_event_cb(off_event_handler, lv.EVENT.ALL, None)
                slider0.add_event_cb(slider0_event_handler, lv.EVENT.ALL, None)
                button0.add_event_cb(button0_event_handler, lv.EVENT.ALL, None)
                page0.screen_load()
                wlan = network.WLAN(network.STA_IF)
                rotary = Rotary()
                wlan.connect('bencab', 'arrabal6')
                rotary.set_rotary_value(19)
                mqtt_client = MQTTClient('m5termostato', '192.168.1.34', port=1883, user='user', password='pass', keepalive=33149)
                label1.set_text(str((slider0.get_value()) / 10))
                • O Offline
                  otosan-maker
                    Amani4791
                    Hi there,
                    I updated firmware on my Tab5 and installed UiFlow 2.0 V 2.4.0.
                    I hoped for fixed UI libs, LVGL (M5UI) is not working for me:
                    If I use pictures for button graphics (<30kB) hiding/ showing them to get 2 state feedback is very, very slow!
                    The same graphics work fine/ fluent with old M5GFX, so I assume there must be a bug?
                    Also: it seems that Wifi is not working anymore with V2.4.0: cannot get http calls.
                    (also normally on booting Tab5 shows UIFlow settings page, with V2.4.0 not anymore and if I download project it's not booting...
                    Hopefully you can fix it soon, I hoped to get something running over Christmas holidays ;-)
                    Thanks a lot,
                    Kind regards from Switzerland!
                    Stephan
                    • G Offline
                      GuerillaPlanter
                      Thank you for the M5Stack devices and coding tools. This community forum has been a great help too. I have been successfully using UiFlow2 to create code for a Cardputer. But I think there is a bug in the UiFlow2 web UI and/or m5f2 file format.
                      THIS WORKS: I can save to the cloud, save the project to a local file, and reimport that file, when the script is like:
                      sTestString = None
                      def setup():
                        global sTestString
                        M5.begin()
                        sTestString = 'hello'
                      def loop():
                        global sTestString
                        M5.update()
                      THIS DOESN'T WORK: If I edit it and assign a particular more complex value to the string, I cannot save to the cloud, nor reimport a file saved locally:
                      sTestString = 'OL,1,RW7###jp0 55  j"#k#!7##ih###4up j`%##7#'
                      This string happens to be a line from a teletext page .tti file, which includes some display control codes. Here is a screenshot of the code which can't be saved to the cloud or reimported, in the UiFlow2 UI:
                      Decoding this string's value is:
                      \u004f\u004c\u002c\u0031\u002c\u001b\u0052\u007f\u001b\u0057\u0037\u0023\u0023\u0023\u006a\u0070\u0030\u0020\u0035\u0035\u0020\u0020\u006a\u0022\u0023\u006b\u0023\u0021\u0037\u0023\u0023\u0069\u0068\u0023\u0023\u0023\u0034\u0075\u0070\u0020\u006a\u0060\u0025\u0023\u0023\u0037\u0023
                      While the script cannot be saved to the cloud (there is no response), the project can be saved to a local file. In the .m5f2 project file, the relevant saved value is:
                      <field name=\"VAR\" id=\"usN/c#7FD;q`ieH|V~5K\">sTestString</field><value name=\"VALUE\"><block type=\"text\" id=\"ap8ErHQgaUZ`^d-W-%_I\"><field name=\"TEXT\">OL,1,\u001bR\u001bW7###jp0 55  j\"#k#!7##ih###4up j`%##7#</field></block></value>
                      This local file cannot then by imported again into UiFlow2, giving an "error opening file" message:
                      I believe the problem is related to some unicode characters rather than the " character.
                      • W Offline
                        wmoorefi @ajb2k3
                        I am unable to get BaseX module to work with UI Flow 2.x firmware. I can get it to work with UI Flow 1.x.
                          RBOUMAN58
                          I noticed today uiflow2 is 2.4.4 instead of the 2.4.3 as yesterday.Working with a PaperS3 e-paper, my programs crash on missing fonts
                          AttributeError: type object 'Fonts' has no attribute 'Montserrat24'
                          Also Montserrat18 is mentioned many times.
                          These fonts are the fonts used in the prompts/labels on the screeneditor in uiflow2?
                          Anybody has seen same symptoms, so something wrong with 2.4.4?
                            RBOUMAN58 @RBOUMAN58
                            @RBOUMAN58
                            Got the problem solved, burned the 2.4.4 firmware using M5Burner, problems gone... programs are working again
                            • O Offline
                              Otis68
                              My STAM PLS stopped working after updating from version 2.4.4 to version 2.4.5. I used M5Burner to revert the firmware back to 2.4.4. But the STAM LPC program didn't work. OSError 261
                              • O Offline
                                Otis68
                                Good afternoon from Russia. Sorry for my English. I'm writing through a translator. I have your LTE modem, the NB-IoT2. And it's been sitting idle for almost a year. I wanted to use the NB-IoT2 with a STAM PLC to control a relay. But YOU still don't have proper documentation. Or an example of how it works. Between the modem and the phone. Will the documentation ever be completed?
