    Scan using M5 Unified for IC2 devices for a M5Dial fails
    2 Posts 2 Posters 733 Views
    • V Offline
      VashJuan
      I've an M5 Dial v1.0 (i.e., https://shop.m5stack.com/products/m5stamp-esp32s3-module) with a number of IC2 modules such as:
      • Grove Temperature Sensor (https://www.seeedstudio.com/Grove-Temperature-Sensor.html)
      • Grove-Wio-E5 Wireless Module - STM32WLE5JC (https://www.seeedstudio.com/Grove-LoRa-E5-STM32WLE5JC-p-4867.html)
      • Buzzer v1.3
      I can't access the IC2 devices on port A or B using the M5 Unified library. Why? I'm using latest Arduino IDE on Windows 10 Pro, with latest libraries & board files.
      Here's the code I'm testing with (partially from the M5 support AI) that runs "fine", but never detects a device connected via a M5 Grove cable to port A (G15 = SCL, G13 = SDA) or B (G1 = SCL, G2 = SDA).
      #include <M5Unified.h>
      // Use M5Dial's external I2C bus (Port A pins 15=SCL, 13=SDA)
      #define SCAN_BUS m5::Ex_I2C
      // (Port B uses 21=SCL, 22=SDA per Copilot) - or rather G1 = SCL and G2= SDA per M5Dial documentation)
      // Port B can be used as an alternative I2C bus
      // #define SCAN_BUS m5::Ex_I2C_PortB
      // to scan the M5 Dial's internal ports, use m5::I2C
      // #define SCAN_BUS m5::I2C
      void setup()
          // Initialize M5Dial with default configuration
          auto cfg = M5.config();
          M5.begin(cfg);
          // Configure round display for I2C scanner
          M5.Display.setTextSize(2);
          M5.Display.setTextColor(TFT_WHITE, TFT_BLACK);
          // M5.Display.fillScreen(TFT_BLACK);
          M5.Display.setCursor(20, 60);
          M5.Display.println("M5Dial I2C Scanner");
          M5.Display.drawLine(20, 50, 220, 50, TFT_WHITE);
      void loop()
          M5.update();
          M5.Display.setCursor(20, 80);
          M5.Display.println("Scanning bus...");
          byte address;
          int nDevices = 0;
          int yPos = 120;
          // Scan all valid I2C addresses (0x08 to 0x77)
          for (address = 1; address < 127; address++)
              // Skip reserved addresses 0-7 to prevent bus lockups
              if (address < 8)
                  continue;
              // display progress indicator, every 4 addresses
              if (address % 4 == 0)
                  M5.Display.setCursor(50, 100);
                  M5.Display.printf("Scanning: %d, 0x%02X", address, address);
                  M5.update();
                  delay(75); // brief delay to allow display update
              // Use M5Unified's built-in scanID method for reliable detection
              bool deviceFound = SCAN_BUS.scanID(address);
              if (deviceFound)
                  M5.Display.setCursor(20, yPos);
                  M5.Display.printf("0x%02X", address);
                  Serial.printf("Device %d is at address 0x%02X\n", nDevices, address);
                  delay(2000);
                  nDevices++;
                  yPos += 25;
                  if (yPos > 210)
                      break; // Stop if we run out of screen space
          // Show scan summary
          M5.Display.setCursor(20, 180);
          if (nDevices == 0)
              M5.Display.println("No devices found");
              Serial.println("No I2C devices found");
          else
              M5.Display.printf("%d device(s) found", nDevices);
              Serial.printf("Successfully found %d I2C devices\n", nDevices);
          // Wait for button press to rescan
          M5.Display.setCursor(20, 200);
          M5.Display.println("Press BtnA: rescan");
          while (!M5.BtnA.wasPressed())
              M5.update();
              delay(10);
      I presume M5Dial handles the required pull-up voltage on the pins.
      Other things to check? I don't have other M5 devices, but lots of XIAO trinkets...
        felmue @VashJuan
        Hello @VashJuan
        well, it looks to me that none of the listed devices are actually I2C devices.
        • Grove Temp. Sensor: has an analog out pin (the other is NC) which means it directly sends an analog value
        • Grove Wireless Mod: has RX and TX which means it has an UART interface
        • Buzzer: well, my guess would be that it is not I2C either
