    Flow 2 Execute block
    UiFlow 2.0
    9
    3.8k
    • N
      nunley21
      Hello I was wondering if flow 2 had "Execute block" and if not is there a timline or is this feature going to be added. I would like to be able to use both the block system and custom code.
      • D
        dozauk
        A block to execute custom code?
        I use the Execute code block under System in UIFlow2
        I'm a relative newbie so excuse me if that's not what you meant
          Hello @nunley21
          in UIFlow2 the Execute code block is under System.
          Edit: looks like @dozauk was quicker!
          ProfHusterP 1 Reply Last reply Reply Quote 0
          • ProfHusterP
            ProfHuster @felmue
            @felmue ,
            I am running V2.3.8, and all I see under System is "Execute mpy code (e.g. import)" and "Execute mpy code". I tried putting the block
            Execute mpy code [print("## HELLO ##")]
            in the loop, but it had no effect. In fact, it wasn't translated to python code in the code window.
            Did inserting python code directly get dropped?
            Michael Huster
              felmue @ProfHuster
              Hello @ProfHuster
              hmm, works for me with M5Tab5 UIFlow2 v2.3.9. It also got translated into Python code window.
              • ProfHusterP
                ProfHuster @felmue
                Hello @felmue,
                I only get
                execute mpy code []
                You can see I reloaded and got V2.3.9. I get the same whether I choose a Tab5 or an Atom Echo. Or M5GFX or M5UI for the Tab5.
                  felmue @ProfHuster
                  Hello @ProfHuster
                  below is an example filled with print("hello"):
                  Please also have a look at my example in the UIFlow2 Project Zone called: M5Tab5_ExecuteMpyCodeTest_UIFlow2.3.9
                  • ProfHusterP
                    ProfHuster @felmue
                    @felmue,
                    Thanks, that worked. I think what happened is I clicked on the code window and did some editing, then went back to the blockly panel. It seemed when I did that, the blockly no longer updated the actual python code.
                    I will check out your examples,
                    Prof Huster
                      felmue @ProfHuster
                      Hello @ProfHuster
                      yes, that is what I observed too. As long as edit mode in Python code window is enabled, changes on the blockly side get ignored. (I guess that's to prevent changes from being overwritten.)
