    Trying to compile Core example from M5Stack github
    6 Posts 4 Posters 4.0k Views
    • teastainT Offline
      teastain
      I am trying to compile the Core Basic example from M5Stack github examples:
      https://github.com/m5stack/M5Stack/blob/master/examples/Basics/Button/Button.ino
      I keep getting this error"
      Arduino/libraries/M5Stack/src/utility/pngle.c:31:10: fatal error: rom/miniz.h: No such file or directory
         31 | #include <rom/miniz.h>
      compilation terminated.
      exit status 1
      Because of this I recently erased my entire Arduino IDE down to the Arduino15 folder and only reinstalled the latest:
      Arduino IDE ver2.3.6 and
      esp32 boards 3.2.0 and
      M5Stack boards 3.2.1
      libraries:
      M5Stack latest ver 0.4.6 and all other required dependancies.
      If...(and this is NOT the answer)...I revert to the old M5Stack boards 2.1.4, it compiles correctly. (and this is NOT the answer).
      I keep my Arduino IDE environment up-to-date, but I have to be carful to not allow the M5Stack boards to update to current.
      This is most tedious.
      What can I do to permanently resolve this, going forward...without downgrading to an old M5Stack boards def like 2.1.4.
      (This effects Core2, btw)
      ?How to install rom/miniz and compile OK?
      Cheers, Terry
      (@felmue do you have any ideas?)
      felmueF H 2 Replies Last reply Reply Quote 0
      • felmueF Online
        felmue @teastain
        Hello @teastain
        I am afraid I cannot help, sorry. I exclusively use Visual Studio Code with PlatformIO / pioarduino (which so far doesn't have this issue).
        Note: Visual Studio Code / PlatformIO doesn't use M5Stack boards and setting up new Cores (M5Stack and others) can sometimes be quite difficult as well.
          HappyUser @teastain
          @teastain
          Change in pngle.c into include <miniz.h> maybe?
          Regards
          • W Offline
            wavydavy
            You can try replacing the following line in the Sketch:
            #include <M5Stack.h>
            With:
            #include <M5Unified.h>
            That should resolve the compilation error.
            teastainT 2 Replies Last reply Reply Quote 1
            • teastainT Offline
              teastain @wavydavy
              @wavydavy I'll try that!
              • teastainT Offline
                teastain @wavydavy
                @wavydavy
                Yes, that resolved the issue, I am now using the
                "M5Stack by M5Stack official 3.2.2 installed " board def.
                The entire problem was that my pre-existing code AND the M5Stack Github examples by M5Stack use
                instead of M5Unified.
                Thanks for your help.
                Also:
                No one at M5Stack picked up on this, except you, not even the online M5Stack AI chat helper.
                Note: The examples in the newer web based API work fine, just not the old M5Stack official Github.
                Cheers, Terry
