    Core2 and M5Unified display no longer works
    9 Posts 4 Posters 4.6k Views
      HappyUser
      Wow,
      I have uploaded the standard M5Unified Button code to my M5Core2.
      I know the program is running because my serial.print shows button counts.
      But the display shows nothing.
      I have tried this on multiple Core2 of which I know the display is not defect. All boards and libs are updated (as fwr as i know).
      What am i doing wrong here?
      #include <M5Unified.h>
      void setup(void)
        Serial.begin(115200);
        /// For models with EPD : refresh control
        M5.Display.setEpdMode(epd_mode_t::epd_fastest); // fastest but very-low quality.
        if (M5.Display.width() < M5.Display.height())
        { /// Landscape mode.
          M5.Display.setRotation(M5.Display.getRotation() ^ 1);
      void loop(void)
        M5.delay(1);
        M5.update();
      //------------------- Button test
      /// List of available buttons:
        M5Stack BASIC/GRAY/GO/FIRE:  BtnA,BtnB,BtnC
        M5Stack Core2:               BtnA,BtnB,BtnC,BtnPWR
        M5Stick C/CPlus:             BtnA,BtnB,     BtnPWR
        M5Stick CoreInk:             BtnA,BtnB,BtnC,BtnPWR,BtnEXT
        M5Paper:                     BtnA,BtnB,BtnC
        M5Station:                   BtnA,BtnB,BtnC,BtnPWR
        M5Tough:                                    BtnPWR
        M5Atom M5AtomU:              BtnA
        M5Stamp Pico/C3/C3U:         BtnA
        static constexpr const int colors[] = { TFT_WHITE, TFT_CYAN, TFT_RED, TFT_YELLOW, TFT_BLUE, TFT_GREEN };
        static constexpr const char* const names[] = { "none", "wasHold", "wasClicked", "wasPressed", "wasReleased", "wasDeciedCount" };
        int w = M5.Display.width() / 5;
        int h = M5.Display.height();
        M5.Display.startWrite();
        /// BtnPWR: "wasClicked"/"wasHold"  can be use.
        /// BtnPWR of CoreInk: "isPressed"/"wasPressed"/"isReleased"/"wasReleased"/"wasClicked"/"wasHold"/"isHolding"  can be use.
        int state = M5.BtnPWR.wasHold() ? 1
                  : M5.BtnPWR.wasClicked() ? 2
                  : M5.BtnPWR.wasPressed() ? 3
                  : M5.BtnPWR.wasReleased() ? 4
                  : M5.BtnPWR.wasDecideClickCount() ? 5
                  : 0;
        if (state)
          M5_LOGI("BtnPWR:%s  count:%d", names[state], M5.BtnPWR.getClickCount());
          M5.Display.fillRect(w*0, 0, w-1, h, colors[state]);
        /// BtnA,BtnB,BtnC,BtnEXT: "isPressed"/"wasPressed"/"isReleased"/"wasReleased"/"wasClicked"/"wasHold"/"isHolding"  can be use.
        state = M5.BtnA.wasHold() ? 1
              : M5.BtnA.wasClicked() ? 2
              : M5.BtnA.wasPressed() ? 3
              : M5.BtnA.wasReleased() ? 4
              : M5.BtnA.wasDecideClickCount() ? 5
              : 0;
        if (state)
          M5_LOGI("BtnA:%s  count:%d", names[state], M5.BtnA.getClickCount());
          M5.Display.fillRect(w*1, 0, w-1, h, colors[state]);
          Serial.println(M5.BtnA.getClickCount());
        state = M5.BtnB.wasHold() ? 1
              : M5.BtnB.wasClicked() ? 2
              : M5.BtnB.wasPressed() ? 3
              : M5.BtnB.wasReleased() ? 4
              : M5.BtnB.wasDecideClickCount() ? 5
              : 0;
        if (state)
          M5_LOGI("BtnB:%s  count:%d", names[state], M5.BtnB.getClickCount());
          M5.Display.fillRect(w*2, 0, w-1, h, colors[state]);
        state = M5.BtnC.wasHold() ? 1
              : M5.BtnC.wasClicked() ? 2
              : M5.BtnC.wasPressed() ? 3
              : M5.BtnC.wasReleased() ? 4
              : M5.BtnC.wasDecideClickCount() ? 5
              : 0;
        if (state)
          M5_LOGI("BtnC:%s  count:%d", names[state], M5.BtnC.getClickCount());
          M5.Display.fillRect(w*3, 0, w-1, h, colors[state]);
        state = M5.BtnEXT.wasHold() ? 1
              : M5.BtnEXT.wasClicked() ? 2
              : M5.BtnEXT.wasPressed() ? 3
              : M5.BtnEXT.wasReleased() ? 4
              : M5.BtnEXT.wasDecideClickCount() ? 5
              : 0;
        if (state)
          M5_LOGI("BtnEXT:%s  count:%d", names[state], M5.BtnEXT.getClickCount());
          M5.Display.fillRect(w*4, 0, w-1, h, colors[state]);
        M5.Display.endWrite();
      #if !defined ( ARDUINO ) && defined ( ESP_PLATFORM )
      extern "C" {
        void loopTask(void*)
          setup();
          for (;;) {
            loop();
          vTaskDelete(NULL);
        void app_main()
          xTaskCreatePinnedToCore(loopTask, "loopTask", 8192, NULL, 1, NULL, 1);
      #endif
      • henryCharmH Offline
        henryCharm
        The problem is caused by a line in your code that sets the display to "EPD mode," which is only for e-paper (e-ink) displays. The M5Core2 uses an LCD screen, not an e-paper screen.
        This line:
        is not compatible with the M5Core2 screen.
        To fix the issue:
        Remove or comment out that line from your code.
        After doing this, the display should start working normal
        From a Data Science Intern to now happy as a IoT Solutions Architect.
          felmue @henryCharm
          Hello @HappyUser
          hmm, the button sample code works fine as it is for me. Tested with M5Core2 and M5Core2 v1.1.
          For reference: I was using Arduino library v3.2.1, M5Unfied v0.2.8 and M5GFX v0.2.13.
          @henryCharm : you are correct, the line M5.Display.setEpdMode(epd_mode_t::epd_fastest); is only used / required for ePaper however it is simply ignored on non ePaper displays. So yes, it would be cleaner to remove the line, but I don't think it does any harm. I think the reason it is there is so that the example works on different M5Cores.
            HappyUser @felmue
            @felmue said in Core2 and M5Unified display no longer works:
            Dear all.
            @Felix : what do you exactly mean with Arduino library v3.2.1,?
            My settings:
            Arduino IDE 2.3.6
            M5GFX : 0.2.13
            M5Unified 0.2.8
            Arduino ESP32 Boards 2.0.18
            M5Core2 display stays black. I have tried the same software on an M5Stick. Display also stays Black,
            Software is running. Serial.print also shows the correct display dimensions.
            Tried the software on a M5CoreS3 and the display is responding!!
            Tried the software in M5Core2 AWS link text. and the display is responding!
            So apparantly for the M5Core2 and M5Stick I am missing something. M5CoreS3 works like expected?
            Anyone a clue?
            I am really grateful.
            (*As i noticed that the height and widt of the screen are correcty read and the buttons appear to be working, could it be that the backlight is just off?. Mind you, i have ttried on several devices so it is not a failure of one device *)
              HappyUser @HappyUser
              @HappyUser
              Further research
              Tried the default M5GFX Bargraph example (attached)
              No display on M5Stick and M5COre2
              Works perfect on M5StickCPlus and M5CoreS3
              This is realy weird.
              I hope someone can help
              #include <arduino.h>
              #include <M5GFX.h>
              M5GFX display;
              //#include <M5UnitOLED.h>
              //M5UnitOLED display; // default setting
              //M5UnitOLED display ( 21, 22, 400000 ); // SDA, SCL, FREQ
              //#include <M5UnitLCD.h>
              //M5UnitLCD display;  // default setting
              //M5UnitLCD display  ( 21, 22, 400000 ); // SDA, SCL, FREQ
              //#include <M5UnitGLASS2.h>
              //M5UnitGLASS2 display;  // default setting
              //M5UnitGLASS2 display ( 21, 22, 400000 ); // SDA, SCL, FREQ
              // #include <M5AtomDisplay.h>
              // M5AtomDisplay display;
              static constexpr size_t BAR_COUNT = 64;
              static int max_y[BAR_COUNT];
              static int prev_y[BAR_COUNT];
              static uint32_t colors[BAR_COUNT];
              void setup(void)
                display.init();
                display.startWrite();
                display.fillScreen(TFT_BLACK);
                if (display.isEPD())
                  display.setEpdMode(epd_mode_t::epd_fastest);
                if (display.width() < display.height())
                  display.setRotation(display.getRotation() ^ 1);
                for (int x = 0; x < BAR_COUNT; ++x)
                  prev_y[x] = display.height();
                  max_y[x] = display.height();
                  int r=0,g=0,b=0;
                  switch (x >> 4)
                  case 0:
                    b = 255;
                    g = x*0x11;
                    break;
                  case 1:
                    b = 255 - (x&15)*0x11;
                    g = 255;
                    break;
                  case 2:
                    g = 255;
                    r = (x&15)*0x11;
                    break;
                  case 3:
                    r = 255;
                    g = 255 - (x&15)*0x11;
                    break;
                  colors[x] = display.color888(r,g,b);
              void loop(void)
                int h = display.height();
                static int i;
                ++i;
                display.waitDisplay();
                  int y = (h>>1) - (sinf((float)((x-24)*i) / 3210.0f) + sinf((float)((x-40)*i) / 1234.0f)) * (h>>2);
                  int xpos = x * display.width() / BAR_COUNT;
                  int w = ((x+1) * display.width() / BAR_COUNT) - xpos - 1;
                  if (max_y[x]+1 >= y) { max_y[x] = y-1; }
                  else
                    if ((i & 3) ==0 )
                      display.fillRect(xpos, max_y[x]-3, w, 1, TFT_BLACK);
                      max_y[x]++;
                  display.fillRect(xpos, max_y[x]-3, w, 3, TFT_WHITE);
                  if (prev_y[x] < y)
                    display.fillRect(xpos, prev_y[x], w, y - prev_y[x], TFT_BLACK);
                  else
                    display.fillRect(xpos, y, w, prev_y[x] - y, colors[x]);
                  prev_y[x] = y;
                display.display();
                felmue @HappyUser
                Hello @HappyUser
                I mean this arduino library.
                Maybe this article helps.
                Note: I am using Visual Code (and not Arduino IDE).
                  HappyUser @felmue
                  Well, strange behaviour is not seldomly caused by strange root causes.
                  I already explained that after upload, the program seems to be running normal, only the screen stays dark.
                  After a lot of trial and error, it seems that it is to do with how the software is uploaded. We are using CH9102 or CP210x (not even sure which one). But the reality is that after uploading, poweing off the Core2, the screen seems to function normal. This is repeated behaviour detected with several M5Core2. Probably we need to upgrade one of the driver. Still hesitating about that because on OSX upgrading can be a risky business. Anyway, it appears to be solved (dont understand it btw).
                  Regards
                    scaven92 @HappyUser
                    @HappyUser I am running into the same problem. I had to remove the battery as the device would get into an unstable state and this made it easier to reset. I find I have to unplug the USB cable, which is powering the board multiple times to get it to work properly. Often having to perform this cycling 5-10 times until it works properly. The HW is working fine on the shipped demo firmware and I have confirmed this behavior on 5 devices. This seems like an initialization of the PMIC or the SPI interface that is non-deterministic or borderline. This only happened once I had to switch to the M5Unified.h library. Very disappointed at the moment.
                      scaven92 @scaven92
                      I should note that I am also using the SD card interface and whenever the SD is not detected on power up the display doesn't work either. I believe they are on the same bus.
