    M5StamPLC and the Backlight
    2.5k
    • G
      GermanSheepDog
      I would like to turn off the backlight of the M5StamPLC when there's nothing to see.
      The set_backlight function from the M5 library doesn't seem to work. The reason
      is probably that there is no "normal" LCD_BL pin:
      // Display
      #define STAMPLC_PIN_LCD_MOSI 8
      #define STAMPLC_PIN_LCD_MISO 9
      #define STAMPLC_PIN_LCD_SCLK 7
      #define STAMPLC_PIN_LCD_DC 6
      #define STAMPLC_PIN_LCD_CS 12
      #define STAMPLC_PIN_LCD_RST 3
      #define STAMPLC_PIN_LCD_BUSY -1
      #define STAMPLC_PIN_LCD_BL -1
      In the M5StamPLC, the PI4IOE5V6408 is responsible for the backlight, and pin 7 is responsible for it.
      Unfortunately, my own routine doesn't work either:
      void my_set_backlight(bool o) {
        PI4IOE5V6408_Class p;
        // false input, true output
        p.setDirection(7, true);
        // false off, true on ?
        p.digitalWrite(7, o);
      Does anyone have an idea, or even better, a solution?
      • G
        GermanSheepDog @GermanSheepDog
        The solution from Chat.M5Stack.com didn't work either:
        #include <M5StamPLC.h>
        #include <Wire.h>
        #define PI4IOE5V6408_ADDR 0x43  // I2C-address
        #define DIR_REG 0x06
        #define OUTPUT_REG 0x02
          M5StamPLC.begin();  // Initialisiert I2C-Bus (G15=SCL, G13=SDA)
          // P7 (LCD_BL) is output, Set Bit 7 of DIR_REG = 0
          Wire.beginTransmission(PI4IOE5V6408_ADDR);
          Wire.write(DIR_REG);
          Wire.write(0x7F);  // 0b01111111 (only P7=output)
          Wire.endTransmission();
        void setBacklight(bool on) {
          Wire.write(OUTPUT_REG);
          Wire.write(on ? 0xFF : 0x7F);  // P7=1 (on) or 0 (off)
          felmue @GermanSheepDog
          Hello @GermanSheepDog
          your my_set_backlight() function works for me and my_set_backlight(true) turns the backlight off (inverted logic).
          void setup()
            auto cfg = M5.config();
            cfg.serial_baudrate = 115200;
            M5.begin(cfg);
            M5StamPLC.begin();
          void loop()
            M5.update();
            if(M5.BtnA.wasClicked() == true)
              Serial.println("BtnA clicked - backlight on");
              my_set_backlight(false);
            if(M5.BtnC.wasClicked() == true)
              Serial.println("BtnC clicked - backlight off");
              my_set_backlight(true);
          P.S. the AI generated code did not work for me.
            felmue @felmue
            below is an alternative function which works for me too:
            #define OUTPUT_REG 0x05
              uint8_t data = M5.In_I2C.readRegister8(PI4IOE5V6408_ADDR, OUTPUT_REG, 200000);
              if(o == true) data |= 0b10000000;
              else data &= ~0b10000000;
              M5.In_I2C.writeRegister8(PI4IOE5V6408_ADDR, OUTPUT_REG, data, 200000);
            • G
              GermanSheepDog @felmue
              Hello @felmue,
              thank you very much for your quick support, it really helped me.
              It didn't work in my "big" program, but I wrote a small test program, and it fully meets the requirements:
                p.setDirection(7, true);  // false input, true output
                p.digitalWrite(7, !o);    // false on, true off
              void printAndWait(String s) {
                M5StamPLC.Display.println(" " + s);
                delay(4000);
                Serial.begin(115200);
                M5StamPLC.begin();
                M5StamPLC.Display.setTextSize(3);
                M5StamPLC.Display.fillScreen(TFT_BLACK);
                M5StamPLC.Display.setCursor(0, 10);
                printAndWait("Test 1");
                printAndWait("Test 2");
                printAndWait("Test 3");
                printAndWait("Test 4");
              You can see it not only in the dark screen, but also in the power consumption, which is reduced by about 20%.
              I suspect that in my "big" program, someone is turning the lights back on (and working against me).
              Best regards,
              Uwe
