    [HELP] Audio From M5Stack Atom Echo Appears Sped Up / Choppy / Low Quality
    Atom
    • E
      echodine46
      Hi everyone,
      I'm working on a project using the M5Stack Atom Echo to stream audio over Wi-Fi to a Python socket server and save it as a .wav file. However, I’ve been consistently running into the following audio quality issues:
      • Audio sounds sped up or accelerated
      • Audio degrades with repeated runs, especially compared to the quality after a fresh flash of the device
      • Low fidelity or choppy output
      • Sometimes segments of the audio are missing intermittently and unpredictably
      What I’ve Tried So Far
      To rule out common causes, I’ve implemented the following:
      • Added a magic header (0xAA55) for packet boundary detection
      • Added a CRC32 checksum to verify packet integrity
      • Tracked packet sequence numbers to detect out-of-order or lost packets
      • Tuned record size to 120 samples per packet to avoid fragmentation
      • Increased DMA buffer length and count to prevent underruns
      • Verified no packet loss over Wi-Fi by checking sequence and CRC
      • Used sample rate of 17000 Hz and 16-bit mono audio
      Despite these efforts, the audio still exhibits the above problems.
      My Setup
      Arduino (M5Stack Atom Echo)
      • Records mic input at 17000 Hz, 16-bit mono
      • Sends audio in chunks of 120 samples per packet (with sequence, magic, and CRC)
      • Uses a large circular buffer to avoid data loss during recording
      Python Socket Server
      • Receives packets with proper buffering
      • Validates magic, sequence, and CRC
      • Appends valid audio frames and writes to a .wav file
      Sample Code
      Arduino Code (M5Stack Atom Echo)
      #include <M5Unified.h>
      #include <WiFi.h>
      #include <CRC32.h>
      const char* ssid = "xxx";
      const char* password = "xxx";
      const char* server_ip = "xx.xx.xx.xx";
      const uint16_t server_port = 5000;
      WiFiClient client;
      CRC32 crc;
      // Reduce packet size to avoid WiFi fragmentation (MTU < 1400 bytes)
      static constexpr size_t record_length = 120;  // Reduced from 240
      static constexpr size_t record_number = 256;  // Larger buffer
      static constexpr size_t record_samplerate = 17000;
      static constexpr size_t record_size = record_number * record_length;
      static size_t rec_record_idx = 0;
      static uint32_t packet_seq = 0;
      int16_t* rec_data;
      bool is_connected = false;
      // Packet with header (magic + seq + crc)
      struct AudioPacket {
        uint16_t magic;  // 0xAA55 for boundary detection
        uint32_t seq;
        uint32_t crc;
        int16_t data[record_length];
      } __attribute__((packed));
        Serial.begin(115200);
        M5.Speaker.end();
        // Configure mic for 16-bit mono 17000Hz
        auto mic_cfg = M5.Mic.config();
        mic_cfg.sample_rate = 17000;
        mic_cfg.stereo = true;  // Force mono
        mic_cfg.dma_buf_len = record_number;  // Larger DMA buffer to avoid underflow
        mic_cfg.dma_buf_count = 8;
        M5.Mic.config(mic_cfg);  // Apply config
        M5.Mic.begin();  // Initialize mic with default config
        // Allocate buffer
        rec_data = (int16_t*)heap_caps_malloc(record_size * sizeof(int16_t), MALLOC_CAP_8BIT);
        memset(rec_data, 0, record_size * sizeof(int16_t));
        // Wi-Fi connection with retry
        WiFi.begin(ssid, password);
          delay(500);
          Serial.print(".");
        Serial.println("\nWi-Fi connected");
        // Reconnect if disconnected
        if (!client.connected()) {
          is_connected = client.connect(server_ip, server_port);
          if (is_connected) {
            Serial.println("Server connected");
            packet_seq = 0;  // Reset sequence on new connection
          } else {
            delay(1000);
            return;
        if (client.connected() && M5.Mic.isEnabled()) {
          AudioPacket packet;
          auto data = &rec_data[rec_record_idx * record_length];
          if (M5.Mic.record(data, record_length, record_samplerate)) {
            // Fill packet with magic number and reset CRC
            packet.magic = 0xAA55;
            packet.seq = packet_seq++;
            crc.reset();  // Critical: reset CRC for each packet
            memcpy(packet.data, data, record_length * sizeof(int16_t));
            packet.crc = crc.calculate((uint8_t*)&packet.data, record_length * sizeof(int16_t));
            client.write((uint8_t*)&packet, sizeof(AudioPacket));
            delay(10);
            if (++rec_record_idx >= record_number) {
              rec_record_idx = 0;
      import socket
      import wave
      import struct
      import zlib
      import numpy as np
      import sounddevice as sd
      HOST = '0.0.0.0'
      PORT = 5000
      OUTPUT_FILE = 'recorded_audio.wav'
      SAMPLE_RATE = 17000
      CHANNELS = 1
      SAMPLE_WIDTH = 2
      RECORD_LENGTH = 120  # Must match Arduino
      PACKET_SIZE = 2 + 4 + 4 + (RECORD_LENGTH * 2)  # magic(2) + seq(4) + crc(4) + data
      frames = []
      last_seq = -1
      buffer = b''
      try:
          with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as sock:
              sock.bind((HOST, PORT))
              sock.listen(1)
              conn, addr = sock.accept()
              with conn:
                  print(f"Connected by {addr}")
                  while True:
                      # Handle fragmented data by buffering
                      buffer += conn.recv(1024)
                      while len(buffer) >= PACKET_SIZE:
                          # Extract complete packet
                          packet = buffer[:PACKET_SIZE]
                          buffer = buffer[PACKET_SIZE:]
                          # Verify magic number
                          magic, seq, crc_received = struct.unpack('<HII', packet[:10])
                          if magic != 0xAA55:
                              print("Invalid packet magic number")
                              continue
                          # Verify sequence
                          if seq != last_seq + 1:
                              print(f"Sequence error: expected {last_seq + 1}, got {seq}")
                          last_seq = seq
                          # Verify CRC
                          audio_data = packet[10:]
                          crc_calculated = zlib.crc32(audio_data) & 0xFFFFFFFF
                          if crc_received != crc_calculated:
                              print(f"CRC error: received {crc_received}, calculated {crc_calculated}")
                              continue
                          frames.append(audio_data)
      except:
          # Save WAV
          with wave.open(OUTPUT_FILE, 'wb') as wf:
              wf.setnchannels(CHANNELS)
              wf.setsampwidth(SAMPLE_WIDTH)
              wf.setframerate(SAMPLE_RATE)
              wf.writeframes(b''.join(frames))
          print(f"Audio saved to {OUTPUT_FILE}")
      Recorded Audio
      Any advice or pointers would be greatly appreciated.
      Thanks in advance.
