    4-20 mA Unit with wemos S2 mini ESP32
    Modules
    9.0k
    • O
      obstbauer @felmue
      @felmue Hello,
      thank you very much, it works !
      I added
      cr.begin(&Wire, MODULE_4_20MA_ADDR, 33, 18, 100000UL);
      to void setup
      • O
        obstbauer
        it seems that I still have a problem....
        I have a current reading but the value is wrong,
        I get soemthing around 7.2 mA instead of 4 mA.
        I can measure the 4 mA with a multimeter in the circuit and the sensor should send 4 mA, so this is ok, but the M5Stack unit shows 7.2 mA and I don't understand why ? Any ideas ?
        My sensor is passive, I connected 24 V to the 4-20mA unit and all three jumpers are installed
        What is the meaning of the function "getCalCurrent" ? It is neessary for the current measurement ? It is necessary to set a "ref current" ?
        Thank you!
        • robskiR
          robski @obstbauer
          @obstbauer try calibration function based on what you see with multimeter
          • O
            obstbauer @robski
            @robski thanks for the answer
            so you mean if I measure with multimter 4.0 mA (which is true for the sensor) and the unit shows me 7.2 mA I should set the calibrated value to 4.0 ?
            Because this is not mentioned anywhere in a readme file or manual or in the description of the device, and it is not made in the example file at github
            but I am a beginner....
            • robskiR
              robski @obstbauer
              @obstbauer thats what i did with mine initially, calibrate with known current value
              • O
                obstbauer @robski
                @robski ok I think I found it:
                thank you I will try tomorrow
                • robskiR
                  robski @obstbauer
                  @obstbauer yeah thats the registers table, I used Uiflow2 with calibration block but you are using not M5Stack controller I see
                  • O
                    obstbauer @robski
                    @robski what value do you take for "index" in the function
                    void MODULE_4_20MA::setCalCurrent(uint8_t index, uint16_t value)
                    • robskiR
                      robski @obstbauer
                      @obstbauer haven't used index value
                      in uiflow2 ..ain4_20ma_0.set_cal_current(10) to set 10mA
                      ain4_20ma_0.set_cal_current(20) to set 20mA
                      • O
                        obstbauer @robski
                        @robski yes maybe in uiflow2 but the function for the c program asks for an index and a value
                        • O
                          obstbauer @obstbauer
                          I see really strange behaviour and I don't know the reason and I get no answers from the support.....
                          The example code from M5Stack say that the currentvalue should be divided by 100:
                          canvas.printf("Current:%.2fmA", (float)(meter.getCurrentValue(0)) / 100.0);
                          The values I get I have to divide by 10 to get the right current in mA.... and the other issue is that I can only use half of the measurement range, at 12.5 mA the ADC sends 65520...
                          maybe someone has an idea ?
                          • O
                            change to a raspberry PI4 seems to be no solution too.....
                            it woud be nice if there would be a better documentation for people who want to use the units outside the m5stack universum....
                            • robskiR
                              robski @obstbauer
                              @obstbauer this is uiflow example with raw value and float too
                              • O
                                obstbauer
                                thank you, but I am still not able to read out or to set the cal current
                                M5Stack support doesn`t answer my mails... and it seems that there is nobody from the company around here, I think I will change to another board with better support
                                • robskiR
                                  robski @obstbauer
                                  @obstbauer TBH if you are using M5Stack modules/units with not M5Stack controllers maybe its worth to have at least one M5Controller (atom?stick? )to be able to check module functionality
