    Trouble w/ Stepmotor Driver Module v1.1 & UiFlow2
    Modules
    • C
      cristian.spiescu
      The sample code didn't work for me out of the box. W/ the following modifications, it kind of works:
      1/ I needed to switch this to disable (or eliminate the line). Really curious. You give the command "please enable", and it does the opposite. In my opinion this is a bug.
      2/ It took a lot of trial and error to understand the purpose of setting the PWM freq. I was wondering myself whether it reduces the voltage like in a H-bridge/normal DC motor? Or it controls how much increments per time unit (sec?)? In my case (a NEMA 23 motor). I understood that its the later.
      • 1000 (1kHz) is way too much.
      • 100: the motor spins, but quite un-smooth
      • 300: the motor spins smoothly
      • 1: an increment each second
      My question is the following: how can I use precise movement? If I tell it "please rotate w/ 50 increments per second", it does the work. But how can I know when those increments finished? Using a timer doesn't seem the right thing to do. I saw that other libs, have this kind of "feedback". Or I'd need an API where I say: please move X increments (instead of saying please move at a rate of Y increments per second).
      • C
        cristian.spiescu @cristian.spiescu
        My findings:
        I'm pretty sure we are talking about a bug. I.e. that boolean is somehow interpreted negated.
        I'm pretty sure the answer is NO (using this lib). I struggled a bit and wrote myself some code. But I ended using another lib. More info in this post.
