    Ultrasonic I2C module and using port B and Port C on Core2 for AWS with the included library
    4 Posts 3 Posters 2.2k Views
      tdahbura
      I have an Ultrasonic I2C module and am trying to use it with the AWS Core 2 device. It works fine on port a, but am trying to use port b or port c for the I2C commications. I am using the Arduino development environment and the code in place that works with port a is this:
      SONIC_I2C sensor;
      sensor.begin();
      newvalue = sensor.getDistance(); //this is returned in mm
      CoreS3.Lcd.printf("%.2f mm", newvalue);
      I do not know how to do the same with the sensor plugged into Port B or Port C?
      thanks for any assistance!
      teastainT ajb2k3A 2 Replies Last reply Reply Quote 0
      • teastainT Offline
        teastain @tdahbura
        @tdahbura Deleted previous post with assertions that did not pan out in my tests!
        Sorry
          ajb2k3 @tdahbura
          @tdahbura You cant use it on port B because the port has one hardware fixed output pin and one hardware fixed input pin.
          Port C is attached to dedicated UART pins.
          For port B you need the PortB version of the sensor or use a the PaHub .
            tdahbura @ajb2k3
            @ajb2k3 thanks.
            I did not there was a different port version of the sensor?
