    PaperS3 cannot compile demo
    5
    808
    • J
      JNVoirol
      I just got My M5PaperS3 and I try to compiler the demo as shown in the tutorial Adruino M5PaperS3 but if get the following error:
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c: In function 'init_bus_gpio':
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c:339:28: error: 'lcd_periph_signals' undeclared (first use in this function); did you mean 'rmt_periph_signals'?
      339 | DATA_LINES[i], lcd_periph_signals.panels[0].data_sigs[i], false, false
      | rmt_periph_signals
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c:339:28: note: each undeclared identifier is reported only once for each function it appears in
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c: In function 'init_lcd_peripheral':
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c:487:26: error: 'lcd_periph_signals' undeclared (first use in this function); did you mean 'rmt_periph_signals'?
      487 | periph_module_enable(lcd_periph_signals.panels[0].module);
      | rmt_periph_signals
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c: In function 'deinit_lcd_peripheral':
      c:\Users{user}\Documents\Arduino\libraries\epdiy\src\output_lcd\lcd_driver.c:562:25: error: 'lcd_periph_signals' undeclared (first use in this function); did you mean 'rmt_periph_signals'?
      562 | periph_module_reset(lcd_periph_signals.panels[0].module);
      | rmt_periph_signals
      exit status 1
      Where the lcd_periph_signals should be defined ?
      • J
        JNVoirol
        I found the mistake: replace "lcd_periph_signals" by "lcd_periph_rgb_signals.
        • kurikoK
          kuriko @JNVoirol
          @JNVoirol
          Just switch the esp32 library version in the boards manager to below 3.1.0.
          • J
            jjkff
            I have a similar Probelm:
            Following the tutorial and using M5GFX 0.2.3 (same with 0.2.2), and epdiy 2.0.0 installed, i get multiple errors in compiler as soon as i switch to PSRAM= OPI PSRAM
            /Documents/Arduino/libraries/M5GFX/src/M5GFX.cpp:84:16 (repeating until /Users/jank/Documents/Arduino/libraries/M5GFX/src/M5GFX.cpp:91:16)
            "error: 'struct lcd_bus_config_t' has no member named 'data'; did you mean 'data_0'?
            90 | lcd_config.data[6] = D6;
            | data_0"
            • the same with D0-D7
            if i dont use PSRAM, it compiles, but wont display anything.
            Setup:
            Arduino IDE 2.3.2
            Board: ESP32S3 DEV
            Lib: esp32 (espresserif) 3.0.4 (same with 3.0.7)
            M5Core1.0,
            M5Unified 0.2.2
            Epdiy 2.0.0 (same with 7.0)
            • Q
              quentino35
              I have the same problem. Has anyone found a solution?
