    How can I use AtomS3R's PSRAM with UIFlow2.0?
    Atom
    2.4k
    • U
      UIgAVvwEs
      I thought I could use 8MB of AtomS3R's PSRAM.
      However I could only use about 100kBytes by with UIFlow2.0.
      (Memory usage was checked using gc.mem_alloc() and gc.mem_free(). )
      • Hardware: AtomS3R
      • Firmware: UIFlow2.0 AtomS3R v2.1.9
      Memory Check Sample Program
      import os, sys, io
      import M5
      from M5 import *
      import gc
      def setup():
        print("Allocated:", gc.mem_alloc(), "bytes")
        print("Free:", gc.mem_free(), "bytes")
      def loop():
        M5.update()
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      Result
      Allocated: 27488 bytes
      Free: 87712 bytes
      • kurikoK
        kuriko
        @UIgAVvwEs
        You can try to manually allocate a larger buffer to verify whether the PSRAM is loaded correctly:
        U 3 Replies Last reply Reply Quote 0
        • U
          UIgAVvwEs @kuriko
          @kuriko
          Thank you for the information.
          But I want to reserve as heap memory.
          Because I want to allocate memory as a buffer to be used for HTTP communication by "request2".
          However this problem would be solved if there was a way to allocate the memory allocated by bytearray to the "request2" buffer.
          • U
            UIgAVvwEs @kuriko
            @kuriko
            Hello kuriko,
            I tried manual memory allocation, but it failed.
            Is there any difference from your environment? Did you know anything?
            import os, sys, io
            import M5
            from M5 import *
            long_text = None
            def setup():
              global long_text
              M5.begin()
              long_text = bytearray(1*1024*1024)
            def loop():
              global long_text
              M5.update()
              try:
                setup()
                while True:
                  loop()
                try:
                  print_error_msg(e)
                except ImportError:
            • U
              UIgAVvwEs @kuriko
              @kuriko
              Thank you for advice.
              The problem of AtomS3R's PSRAM not being usable in UIFlow2.0 has been resolved.
              Cause:
              The PSARM enable setting in the following file, which sets the build settings, was missing.
              uiflow_micropython/m5stack/boards/sdkconfig.spiram_oct
              Solution:
              Modify the missing description as shown below, then build the firmware and write it to AtomS3R.
              Before:
              # MicroPython on ESP32-S2 and ESP32-PAD1_subscript_3, ESP IDF configuration with SPIRAM support in Octal mode
              CONFIG_SPIRAM_MODE_QUAD=
              CONFIG_SPIRAM_MODE_OCT=y
              After:
              # MicroPython on ESP32, ESP IDF configuration with SPIRAM support
              CONFIG_SPIRAM=y
              CONFIG_SPIRAM_CACHE_WORKAROUND=y
              CONFIG_SPIRAM_IGNORE_NOTFOUND=y
              CONFIG_SPIRAM_USE_MALLOC=y
              # This is the threshold for preferring small allocations from internal memory
              # first, before failing over to PSRAM.
              CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL=8192
              # SPIRAM increases the size of the firmware and overflows iram0_0_seg, due
              # to PSRAM bug workarounds.  Apply some options to reduce the firmware size.
              CONFIG_COMPILER_OPTIMIZATION_SIZE=y
              CONFIG_COMPILER_OPTIMIZATION_CHECKS_SILENT=y
              # CONFIG_RINGBUF_PLACE_FUNCTIONS_INTO_FLASH=y # Workaround required: see main_esp32/linker.lf
              CONFIG_FREERTOS_PLACE_FUNCTIONS_INTO_FLASH=y
              CONFIG_FREERTOS_PLACE_SNAPSHOT_FUNS_INTO_FLASH=y
              Result:
              8MB of memory space is now available as shown below.
              Souce Code Of "Rseult":
              import os, sys, io
              import M5
              from M5 import *
              import gc
              a = None
              def setup():
                global a
                M5.begin()
                print("--start--")
                print("Mem-Free: " + str(gc.mem_free()))
                print("Mem-Alloced: " + str(gc.mem_alloc()))
                a = bytearray(1*1024*1024)
                print("Memory allocated : about 1MB")
              def loop():
                global a
                M5.update()
                try:
                  setup()
                  while True:
                    loop()
                  try:
                    print_error_msg(e)
                  except ImportError:
              kuriko さんありがとうございます。
              AtomS3RのPSRAMがUIFlow2.0で使用できない問題が解決しました。
              原因:
              ビルド設定を行う下記のファイルのPSARM有効化の設定が不足していました。
              対策:
              不足ている記載を上記英文「After:」のように修正ししてからファームウェアをビルドしAtomS3Rに書き込みます。
              結果:
              下記の様に8MBのメモリ空間が使用可能になりました。
              (日本の方にも情報共有できるよう、日本語併記としました。)
              U 1 Reply Last reply Reply Quote 0
              • U
                UIgAVvwEs @UIgAVvwEs
                @UIgAVvwEs
                Note:
                Base Firmware:
                https://github.com/m5stack/uiflow-micropython/tree/master
                Ver.2.2.0
                Hash: d0ff1edc97401edc0ab9063f0765730c44335b94
                Build Environment:
                • OS: Linux Mint 21.3 Cinamon(*) ... on Hyper-V of Windows
                (* : Because, it was difficult to set up a build environment for "uiflow-micropython" on Windows.)
                • E
                  ewoodier84 @UIgAVvwEs
                  @UIgAVvwEs Is there any way to do this without Linux? I need to do this exact thing but I can only be on windows
                  • U
                    UIgAVvwEs @ewoodier84
                    @ewoodier84
                    I don't know way to do the with out Linux.
                    I used Linux on virtual environment in windows.
                    How about trying virtual environments like Hyper-V or VirtualBox?
