    M5StickPlus2 - esp_core_dump_flash: Core dump flash config is corrupted!
    Units
    1.4k
    • G
      G00TH
      Hi guys, I have a new M5StickPlus2 and probably a bug in the library. When I flash something with the Arduino IDE the flashing is successful but in Console I get the error “esp_core_dump_flash: Core dump flash config is corrupted!” and the stick is stuck in a boot loop. The error only occurs if the library “M5StickCPlus2.h” is included. If I do not include it, I can flash the stick without any problems an the flashed Programm works. I have now tested both available versions of the library but with both I get the same error.
      Does anyone have any ideas?
      • kurikoK
        kuriko @G00TH
        @G00TH
        I have never encountered this problem, and I don't see any place in M5StickCPlus2.h that may cause this problem. Maybe it is related to Flash Mode? If possible, can you provide your code?
