    AtomS3U serial communication from Atom but not to Atom.... Why?
    Atom
    • I
      ivanurwin
      I am plugging an AtomS3U into a USB port of my Windows 10 laptop and I want to have the AtomS3U emulate my microscope. To do that, I need to send and receive serial characters.
      Completely new to the AtomS3U and UIFlow2, I have just recently managed to get my first progam into the AtomS3U and that works: able to change the colour of the internal LED.
      Now, I want to be able to read and write data on the PCs USB (COM9) connector.
      To test, I am successfully using Putty to talk to COM 9. (115200 baud, 8 data bits 1 stop bit, no parity) Flow control. I have tried with and without XON/XOFF.
      I see Hello World messages from the Atoms3U showing that I have the correct COM port and that the AtomS3U is programmed and working. However when I type something I never see any data available message showing communication works from PC to Atom.
      Why can I communicate in one direction only?
      • kurikoK
        kuriko @ivanurwin
        Hi @ivanurwin
        It seems your computer is sending serial data when the device logic just enters the "Sleep 5 seconds". Try to delete this block to see if it works.
          felmue @kuriko
          Hello @ivanurwin
          the communication between PC and M5AtomS3U happens via native USB (without an external USB/Serial IC) which cannot be used with UIFlow2 UART blocks. UIFlow2 UART blocks define GPIOs for RX and TX (among others) which do not exist for a native USB connection.
          The only UIFlow2 block I see which will read data from the PC via a native USB connection is prompt for text with message.
