    M5StampS3:GPIO3 Analog input don't work
    Modules
    • G
      gohan_oishii
      I am using the analogue input with the M5Stamp S3, but GPIO3 is constantly outputting 4095.
      Other outputs give the correct values.
      I use Arduino IDE 2.3.3, and the code is
        Serial.begin(115200);
        for(int i=1;i<=15;i++){
            pinMode(i,ANALOG);
         int index = 0;
        for (int pin = 1; pin <= 15; pin++) {
          v[index] = analogReadMilliVolts(pin);
          Serial.print(String(v[index]));
          if (index < 13) {
            Serial.print(",");
          index++;
        Serial.println();
        delay(1000);
      felmueF teastainT 2 Replies Last reply Reply Quote 0
        felmue @gohan_oishii
        Hello @gohan_oishii
        GPIO3 on the ESP32S3 is a strapping pin (see here) and is pulled up via external 10 k resistor (see schematic here).
        • teastainT
          teastain @gohan_oishii
