    MQTT message to JSON issues
    UIFlow
    1.3k
    • T
      travisstdenis
      I'm attempting to send JSON data over MQTT and have the M5 load the different key values into labels. I haven't been successful trying it a few different ways. I think part of the problem is that a b' gets added to the beginning of both the topic an message values received by the MQTT software.
      For reference, here is the updateProject function called:
      And here is the JSON string i'm sending over MQTT:
      { "id": 00004578, "shape": "hex", "total": 856, "cut1": 230, "cut2": 184, "cut3": 207, "cut4": 156, "cut5": 143, "clr1": 230, "clr2": 184, "clr3": 207, "clr4": 156, "clr5": 143 }
      First try was this way:
      This give me an error at the line of code in the updateProject function assigning the first label value to the appropriate key/value:
      TypeError: object with buffer protocol required
      The second way was to remove the leading b' that gets inserted (if anyone has a better way to do this, please lmk)
      This gives me an error at the line where it sets projDetails in the MQTT event:
      ValueError: syntax error in JSON
      The third and fourth way was trying the Dump JSON block alone and trying to remove the b'
      Both cases gives the error in the first line of the updateProject function where setting the first label
      TypeError: string indices must be integers, not str
      Then I tried just making the variable the data minus any JSON blocks and put it off to the function to do all the work
      Not sure how to proceed on this. Any help would be greatly appreciated.
        felmue @travisstdenis
        Hello @travisstdenis
        have you tried to use decode to convert bytes into a string (instead of replace)? You'll find decode in the Text group.
        • T
          travisstdenis
          I solved it. See below:
          First step was removing the b' at the beginning and ' at the end
          Then convert that to JSON with "loads json" block
          The "loads json" for the individual elements are redundant and you just pull straight from the json variable
