    Core2 V1.1 cannot control power LED
    7 Posts 4 Posters 3.2k Views
      matthiMarschi
      I have now new Core2 V1.1. The power LED lights now blue (instead green), but the control with power.setPowerLED(True) or power.setPowerLED(False) is no more possible. What is the right control command?
      G H 2 Replies Last reply Reply Quote 0
      • G Offline
        Genesis17 @matthiMarschi
          matthiMarschi
          Has anybody the schematics to the Core2 V1.1?
          • felmueF Online
            felmue @matthiMarschi
            Hello @matthiMarschi
            you can find it here.
            • felmueF Online
              felmue @felmue
              the blue LED by default indicates the battery charger state. If you want to control it, you'll need to set the mode to manual. See example here.
              Note: PR create here.
                matthiMarschi @felmue
                @felmue thanx a lot! I use UiFlow1.1 and an example for LED control in python is here:
                from m5stack import *
                from m5stack_ui import *
                from uiflow import *
                import i2c_bus
                import time
                screen = M5Screen()
                screen.clean_screen()
                i2c0 = i2c_bus.easyI2C((21, 22), 0x00, freq=400000)
                i2c0.addr=(0x34)
                while True:
                i2c0.write_u8(0x69, 0x05)
                wait(1)
                i2c0.write_u8(0x69, 0x35)
                wait(1)
                  HolgerRauls @matthiMarschi
                  @matthiMarschi This one worked fine for me: M5.Axp.SetLed(0);
