    Core2 v1.1 KmeterISO
    5 Posts 4 Posters 3.9k Views
    • B Offline
      bignerd95
      I’m trying to test KmeterISO with core2 v1.1 and UIFlow 2.0
      I connected the KmeterISO to the red port, but if i try ti scan i2c addresses on port A (33, 32) it always shows zero addresses, so it fails to connect to address 0x66
      Any idea?
      Is KmeterISO compatible with Core2 v1.1?
        czm88 @bignerd95
        @bignerd95 Did you ever get this working? I have the same problem, came here looking for help and found this post.
        • teastainT Offline
          teastain @czm88
          @czm88 The Core 2 I2C pins are SDA 32, SCL 33.
          Perhaps this is the problem?
            felmue @teastain
            Hi guys
            KmeterISO unit is available in UIFlow2.1.2. Does it not work? (Note: I don't have that unit so I cannot test.)
            If you want to run an I2C scan (internal and on port A) check out my example in the UIFlow2 Project Zone: M5Core2_I2CScan_Intern_PortA_UIFlow2.1.2
              czm88
              I just wanted to give an update in the event someone comes across the same issue in the future:
              I was able to get the KMeterISO to work with the Core.2 unit and using the Arduino IDE by doing the following:
              • I needed to download the M5Unit-KMeterISO library from GITHUB - https://github.com/m5stack/M5Unit-KMeterISO
              • I used the included "demo" example that was part of the library download but I had to make a few changes: I added a line "#include <M5Core2.h>" to the beginning. Added "M5.begin();" in void setup(), and finally changed the i2c pins from 21 & 22 to 32 & 33 in the kmeter.begin line - "while (!kmeter.begin(&Wire, KMETER_DEFAULT_ADDR, 32, 33, 100000L)) {"
              Here is the complete modified demo example code:
              #include "M5UnitKmeterISO.h"
              #define INTERVAL_TIME 500
              M5UnitKmeterISO kmeter;
              uint8_t error_status = 0;
              long delay_time      = 0;
              long map(long x, long in_min, long in_max, long out_min, long out_max) {
                  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
                  Serial.begin(115200);
                      Serial.println("Unit KmeterISO not found");
                  delay_time = millis() + INTERVAL_TIME;
                  if (millis() > delay_time) {
                      error_status = kmeter.getReadyStatus();
                      if (error_status == 0) {
                          Serial.printf("Celsius Temp: %.2fC\r\n",
                                        ((float)(kmeter.getCelsiusTempValue())) / 100);
                          Serial.printf("Fahrenheit Temp: %.2fF\r\n",
                                        ((float)(kmeter.getFahrenheitTempValue())) / 100);
                          Serial.printf(
                              "Chip Celsius Temp: %.2fC\r\n",
                              ((float)(kmeter.getInternalCelsiusTempValue())) / 100);
                          Serial.printf(
                              "Chip Fahrenheit Temp: %.2fF\r\n",
                              ((float)(kmeter.getInternalFahrenheitTempValue())) / 100);
                      } else {
                          Serial.printf("Error: %d", kmeter.getReadyStatus());
