    Bus already started, M5Stick vs DEVKIT 1
    M5 Stick/StickC
    • P
      PascalS
      Hello to all,
      The M5StickCPlus2 has a weird behaviour in regards to the I2c bus.
      Before my M5Stick arrived, I tested the M5Stack Mini Scale with my Esp32 (Doit Devkit 1) successfully with the following code.
      #include <Arduino.h>
      #include <M5Unified.h>
      #include "UNIT_SCALES.h"
      #include <WiFi.h>
      #include <PubSubClient.h>
      #include <InfluxDbClient.h>
      #include <InfluxDbCloud.h>
      #define millis_between_readings 500
      // WiFi
      const char* ssid = ".....";
      const char* password = "....";
      #if defined(ESP32)
        #include <WiFiMulti.h>
        WiFiMulti wifiMulti;
        #define DEVICE "ESP32"
      #elif defined(ESP8266)
        #include <ESP8266WiFiMulti.h>
        ESP8266WiFiMulti wifiMulti;
        #define DEVICE "ESP8266"
      #endif
      #define INFLUXDB_URL "....."
      #define INFLUXDB_TOKEN "....."
      #define INFLUXDB_ORG "...."
      #define INFLUXDB_BUCKET "...."
      // Time zone info
      #define TZ_INFO "UTC2"
      // Declare InfluxDB client instance with preconfigured InfluxCloud certificate
      InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
      // Declare Data point
      Point sensorP("ESP32_1");
      UNIT_SCALES scales;
      void setup()
        // Setup wifi
        Serial.print("Connecting to WiFi: [");
        Serial.print(ssid);
        Serial.print("] password: [");
        Serial.print(password);
        Serial.print("]");
        Serial.println();
        Serial.print("Connecting to wifi");
        WiFi.mode(WIFI_STA);
        wifiMulti.addAP(ssid, password);
        WiFi.disconnect();
        delay(1);
        while (wifiMulti.run() != WL_CONNECTED) {
          Serial.println(WiFi.status());
          Serial.print(" ");
          delay(1000);
        Serial.println("Connected to the Wi-Fi network");
          // Accurate time is necessary for certificate validation and writing in batches
        // We use the NTP servers in your area as provided by: https://www.pool.ntp.org/zone/
        // Syncing progress and the time will be printed to Serial.
        timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
          // Check server connection
        if (client.validateConnection()) {
          Serial.print("Connected to InfluxDB: ");
          Serial.println(client.getServerUrl());
        } else {
          Serial.print("InfluxDB connection failed: ");
          Serial.println(client.getLastErrorMessage());
        sensorP.addTag("device", DEVICE);
        sensorP.addTag("sensorType", "HT711");
        while (!scales.begin(&Wire, 21, 22, DEVICE_DEFAULT_ADDR))
          Serial.println("scales connect error");
          M5.Lcd.print("scales connect error");
          delay(1000);
      char *toCharArray(String str)
        return &str[0];
      void loop()
        // Clear fields for reusing the point. Tags will remain the same as set above.
        sensorP.clearFields();
        // Delay between measurements.
        sensorP.addField("weight", scales.getWeight());
        sensorP.addField("gap",  scales.getGapValue());
        sensorP.addField("adc",  scales.getRawADC());
        // Write point
        if (!client.writePoint(sensorP)) {
          Serial.print("InfluxDB write failed: ");
        Serial.println("Pausing till next reading");
        delay(millis_between_readings);
      Here is a picture of the wiring I used to bridge the gap between the M5 connector and the Devkit 1. (Green: VIN, Gray: GND, Purple: D21, White D22).
      Anyone any idea what these two boards work differently?
      Greetings Pascal
      • P
        PascalS
        For the sake of completeness, I found my error.
        I assumed, due to the writing on the back, that the ports must be 21/22. However, the SDA/SCL ports for the groove port are 32/33.
        while (!scales.begin(&Wire, 32, 33, DEVICE_DEFAULT_ADDR))
            delay(1000);
        Changing the ports in the scales.begin fixed the error.
        Greetings Pascal
