    why is my m5stickcplus2 not turning on
    M5 Stick/StickC
      stunt_bot
      why is my m5stickcplus2 not turning on i dont know whats wrong with it
      S ajb2k3A 2 Replies Last reply Reply Quote 0
        sonderBUILDS @stunt_bot
        @stunt_bot If you don't know, HOW should we?
        There are a few options:
        • Battery is empty
        • No firmware flashed
        • Firmware is flashed, but enters wrong mode (no Python-script to load)
        To troubleshoot:'
        • connect the device to the computer with a cable.
        • Install drivers, if necessary. Link: https://docs.m5stack.com/en/download
        • Maybe it is necessary to restart the comuter at this point.
        • Open a browser and go to: https://uiflow2.m5stack.com/ and login.
        • Your browser should ask you to connect to a serial device. Select the right COM-Port.
        • and then a consolewindow should start.
        • Look at the output on that window.
        If the console window tells you something like UIFlow, bla bla, then maybe you neet to upload a python file OR flash another firmware (depending on your needs)
        If the console window stays blank, uh oh! I don't know! Maybe you have erased previousely installed firmware and need to reflash it.
        Maybe you need to flash a firmware with the M5 Burner available at: https://docs.m5stack.com/en/uiflow/m5burner/intro
        I hope I could help a bit.
        S B
          ajb2k3 @stunt_bot
          @stunt_bot it’s hard to say, what have you tried?
