    M5Dial backlight control / dimming?
    • E
      ELaw001
      Are there any functions (and/or code examples) available in the Arduino libraries to dim or turn on/off the backlight on the M5Dial?
      I've tried M5.Lcd.setBrightness and M5Dial.Lcd.setBrightness... both compile, but don't seem to do anything.
      Thanks!
        felmue @ELaw001
        Hello @ELaw001
        please have a look at this example here using encoder to dim the backlight.
        • E
          ELaw001 @felmue
          Hey thanks!
          So... funny story... I tried the sketch you linked and it worked fine. Then I tried calling the M5Dial.Display.setBrightness function in my sketch, and it did nothing regardless of what number I passed to it.
          Long story short, I'm using Bodmer's TFT_eSPI library in my sketch and I had TFT_BL defined in the user config file. It seems that defining that makes the TFT_eSPI library take over the backlight control pin and stops the setBrightness function from working. Commenting out the setting of TFT_BL in that config file made the function work.
