    Port.C of boot serial console is IO inverted on CoreMP135.
    Cores
    2.5k
    • N
      nnn
      The boot serial console can be accessed from Grove Port.C on the CoreMP135, via USB serial.
      U-Boot logs are output from Port.C pin 1 (non TX-RX swap signal), while the Linux console is output from Port.C pin 2 (with TX-RX swap signal).
      I would like to see the U-Boot logs and Linux console aligned on the same IO.
      • U-Boot logs
        from Port.C non TX-RX swap signal
      NOTICE:  CPU: STM32MP135D Rev.Y
      NOTICE:  Model: STMicroelectronics STM32MP135F-DK Discovery Board
      NOTICE:  BL2: v2.6-stm32mp1-r1.0(release):2021.05-10169-gb885d5525a
      NOTICE:  BL2: Built : 15:39:25, May 15 2024
      NOTICE:  BL2: Booting BL32
      optee optee: OP-TEE: revision 3.16 (b885d552)
      U-Boot 2021.10-stm32mp-r1 (May 15 2024 - 15:39:22 +0800)
      CPU: STM32MP135D Rev.?
      Board: stm32mp1 in trusted mode (st,stm32mp135f-dk)
      DRAM:  512 MiB
      Clocks:
      - MPU : 650 MHz
      - AXI : 266.500 MHz
      - PER : 24 MHz
      - DDR : 533 MHz
      WDT:   Started with servicing (32s timeout)
      NAND:  0 MiB
      MMC:   STM32 SD/MMC: 0
      Loading Environment from MMC... OK
      In:    serial
      Out:   serial
      Err:   serial
      invalid MAC address 0 in OTP 00:00:00:00:00:00
      Net:   No ethernet found.
      Hit any key to stop autoboot:  0
      Boot over mmc0!
      switch to partitions #0, OK
      mmc0 is current device
      Scanning mmc 0:5...
      Found /boot/extlinux/extlinux.conf
      Retrieving file: /boot/extlinux/extlinux.conf
      160 bytes read in 20 ms (7.8 KiB/s)
      1:      stm32mp135f-coremp135-buildroot
      Retrieving file: /boot/zImage
      7923832 bytes read in 579 ms (13.1 MiB/s)
      append: root=/dev/mmcblk0p5 rw panic=5 quiet rootwait
      Retrieving file: /boot/stm32mp135f-coremp135.dtb
      68116 bytes read in 24 ms (2.7 MiB/s)
      Kernel image @ 0xc2000000 [ 0x000000 - 0x78e878 ]
      ## Flattened Device Tree blob at c4000000
         Booting using the fdt blob at 0xc4000000
         Loading Device Tree to cffec000, end cffffa13 ... OK
      gc2145@3c node not found - DT update aborted
      FDT: cryp@54002000 node disabled for STM32MP135D Rev.?
      Starting kernel ...
      • Linux logs
        from Port.C with TX-RX swap signal
      [    0.004005] /cpus/cpu@0 missing clock-frequency property
      [    0.435138] stm32-cpufreq stm32-cpufreq: OPP-v2 not supported
      Starting syslogd: OK
      Starting klogd: OK
      Starting modules: soundcore success, snd success, snd_timer success, snd_pcm success, snd_pcm_dmaengine success, snd_soc_core success, snd_soc_simple_card_utils success, snd_soc_audio_graph_card success, snd-soc-simple-card success, snd_soc_stm32_sai success, snd_soc_stm32_sai_sub success, cdc-acm success, libcomposite success, g_serial success, OK
      Running sysctl: OK
      Starting mdev... OK
      Seeding 256 bits and crediting
      Saving 256 bits of creditable seed for next boot
      Starting tee-supplicant: Using device /dev/teepriv0.
      OK
      Starting network: OK
      Starting dhcpcd...
      dhcpcd-9.4.1 starting
      DUID 00:01:00:01:2d:f9:ec:09:2a:88:82:9b:b0:f0
      forked to background, child pid 177
      [    5.966541] m_can_platform 4400e000.can can0: bit-timing not yet defined
      [    5.974064] m_can_platform 4400e000.can can0: failed to open can device
      [    5.988759] m_can_platform 4400f000.can can1: bit-timing not yet defined
      [    5.994164] m_can_platform 4400f000.can can1: failed to open can device
      Starting dropbear sshd: OK
      Stopping /etc/rc.localOK
      Welcome to CoreMP135, Powered by M5Stack.
      CoreMP135 login:
      Reference
      https://x.com/ciniml/status/1791303454474014932
      • N
        nnn @nnn
        @nnn
        The uart6 in linux-dts was able to switch IO with rx-tx-swap.
        The uart6 in uboot-dts seems to be fixed, unable to switch IO with rx-tx-swap.
        Is there a HW issue with the Stm32MP135?
        • N
          nnn @nnn
          @nnn
          According to the data sheet, is the IO of UART6 fixed at startup?
          Reference:
          https://www.st.com/ja/microcontrollers-microprocessors/stm32mp135d.html
          https://x.com/ciniml/status/1803093984778277271
            ajb2k3 @nnn
            @nnn Yes its set at startup by the device tree overlay file.
            I finally managed to find the config in the linux DTS file last night.
            In order to redefine it you need to create a new Device Tree config to redefine the pins and functions.
            N 1 Reply Last reply Reply Quote 1
            • N
              nnn @ajb2k3
              This discussion will be continued below
              https://github.com/m5stack/CoreMP135_buildroot-external-st/issues/2
