    M5Dial - questions before buying
    Modules
    988
    • Y
      YigalB
      Hello
      I am using ESP32 dev boards for a while, so the M5Dial looks like a great product for my projects. I have some concerns which I want to consult with the forum about, as I am not sure what features are used and blocked for the M5Dial needs.
      1- Can I program and upload the product from VisualStudioCode (VScode)?
      2- Can I utilize ESPnow? I can give up WiFi as I think they can't work together.
      3- Can I use both cores of the ESP32?
      4- Only 2 IOs and I2C is available for external applications, correct?
      5- Are the 2 GPIOs fully in & out? no restrictions?
      Thank you
      Yigal
      • teastainT
        teastain @YigalB
        -Yes, the examples are available for Python/UIFlow and Arduino IDE, but other editors like PlatformIO and ESP-IDF work fine
        -ESP-NOW works great and my projects are one-or-the-other, but with some tricky control they can share the WiFi band.
        -Yes in FreeRTOS.
        -Correct, both 'ports' have identical usability I2C and or GPIO
        -Essentially they are 4 ESP32 GPIO
        Y 1 Reply Last reply Reply Quote 1
        • Y
          YigalB @teastain
          Thanks for the fast and good answers! Few clarifications:
          @teastain said in M5Dial - questions before buying:
          [Yigal] Very good. ESPnow is exactly what I need. I don't want/need to rely on WiFi.
          -Yes in FreeRTOS.
          [Yigal] Are you sure FreeRTOS is required? So far both cores are working well for me without FreeRTOS. One core is for endless sensors reading, while the other core is ready for ESPnow communication handling. I assume I can keep on the same way, unless I miss something.
          [Yigal] Understood. 4 GPIOs are available (or 2 with I2C which is about the same).
          Which GPIOs are these? I just wanted to make sure these are not the limited ones.
          • teastainT
            teastain @YigalB
            @YigalB FreeRTOS is baked in.
            All four are GPIO.
            The drawing has a minor notation error and to simplify things for new Users there is a suggestion that Port A, red, is I2C and Port B, black, is one in and one out.
            But they are all General Purpose Input-Output.
            https://www.espressif.com/sites/default/files/documentation/esp32-s3_datasheet_en.pdf
            page 16 I/O mux
