    M5Unit 8Servos - push button input
    6 Posts 3 Posters 3.6k Views 1 Watching
      swasi
      Hello everybody
      I would like to use this unit as push button extension. In the examples codes i saw that this module can handle input and output. But there is no description if pins are already debounced and no schematic how the button should be connected is provided.
      Does anybody know how to manage this?
      • teastainT Offline
        teastain @swasi
        @swasi This product?
        https://docs.m5stack.com/en/unit/8Servos Unit
        And what button?
          swasi @teastain
          @teastain yes, exactly this unit.
          My push button is a cheap metal 1NO push button from aliexpress
          https://de.aliexpress.com/item/4000962003511.html?spm=a2g0o.productlist.main.29.28681ZX81ZX8eV&algo_pvid=980580c4-cbbf-4562-8505-6208e49f88f1&algo_exp_id=980580c4-cbbf-4562-8505-6208e49f88f1-14&pdp_npi=4%40dis!CHF!1.57!1.57!!!1.68!1.68!%402103010b17167024952887064e1da1!10000012730074410!sea!CH!2358164638!&curPageLogUid=D8W0ybIwBZDH&utparam-url=scene%3Asearch|query_from%3A
          My idea is to connect it to one port of the M5Unit 8Servos.
          The example on github is here.
          https://github.com/m5stack/M5Unit-8Servo/blob/main/examples/DIGITAL_INPUT_OUTPUT/DIGITAL_INPUT_OUTPUT.ino
          I don't know if i have to connect the push button between S and G on the 8Servos Unit or between V and S. And i'm wondering if i have to debounce the push button in hardware with an RC filter or it's already done in the unit. Or can i debounce the button in my arduino code?
            ajb2k3 @swasi
            @swasi Do Not connect it to V and S as it will destroy the input pins.
            V is at 5V but the I/O pins only accept 3.3V.
            You need to use a circuit like this (the M5stack buttons)
            alt text
              swasi @ajb2k3
              @ajb2k3 thank you very much for your suggestion.
              I think i should pull out my multimeter and check what happens, if i configure the port as input.
              Maybe I'll find out, how it's working.
              The M5buttons schematics shows how to debounce the button input. Thank you very much for this picture.
                swasi @swasi
                I've managed to read button clicks from M5Unit 8Servos.
                Here is how i connected the button to the unit.
                I've managed to read button click from M5Unit 8Servos with this code.
                I'm using an M5Stack AtomS3 Lite.
                #include <Arduino.h>
                #include <M5Unified.h>
                #include <Wire.h>
                #include <M5_UNIT_8SERVO.h>
                #define SERVO_PIN 0
                #define START_BUTTON_PIN 1
                // put variables here:
                M5_UNIT_8SERVO unit_8servo;
                bool btnState;
                unsigned long btnClieckedMs;
                // put function declarations here:
                  Serial.begin(115200);
                  Serial.println("### Setup - start");
                  while (!unit_8servo.begin(&Wire, G2, G1, M5_UNIT_8SERVO_DEFAULT_ADDR)) {
                    Serial.println("extio Connect Error");
                    delay(100);
                  //unit_8servo.setAllPinMode(SERVO_CTL_MODE);
                  unit_8servo.setOnePinMode(SERVO_PIN, SERVO_CTL_MODE);
                  unit_8servo.setOnePinMode(START_BUTTON_PIN, DIGITAL_INPUT_MODE);
                  btnState = false;
                  Serial.println("### Setup - end");
                  bool prevBtnState = btnState;                               // save last state for comparison
                  btnState = unit_8servo.getDigitalInput(START_BUTTON_PIN);   // read new state
                  if(prevBtnState == false && btnState == true) {             // if state has changed
                    btnClieckedMs = millis();                                 // save millis
                  } else if(prevBtnState == true && btnState == false) {      // if state has changed again
                    if(millis() - btnClieckedMs > 50) {                       // check how long it took from 'false' to 'true' (debounce)
                      Serial.print("Button clicked ");                        // do some fancy things when button clicked
                      Serial.println(btnClieckedMs);
