    Arduino & TimerCameraX - webcam examples just don't work
    2.1k
    • J
      jarkman
      I'm trying to use a TimerCameraX with Arduino, with the latest versions of everything.
      Both of the Timer-CAM webcam examples (sta and ap) work for a little while, then become very intermittent, then stop delivering frames altogether.
      Are these examples meant to work correctly with the TimerCameraX ? Should I be looking somewhere else for decent examples ?
      Thanks,
      Richard
        Hello @jarkman
        I assume you already have PSRAM enabled in your build, yes?
        BTW: Not sure why but changing the frame_size from FRAMESIZE_QVGA to the camera native FRAMESIZE_QXGA helped a lot.
        • J
          jarkman
          @felmue - thanks. I had PSRAM enabled but perhaps not the right partition scheme.
          I now have PSRAM enabled and I'm using the default partition scheme ('default 4MB with spiffs...').
          I see it
          • working with FRAMESIZE_QVGA (320x200)
          • working but frequently blocking for several seconds with FRAMESIZE_SVGA (800x600) as in the original sample
          • crashing instantly with FRAMESIZE_QXGA (2048x1536)
          Any thoughts ?
          thanks,
          Richard
            Hello @jarkman
            I am afraid I am out of ideas at this point in time. Sorry.
