    CORES3 with NB-IOT
    4 Posts 2 Posters 2.6k Views 1 Watching
      markpro
      Hi!
      I have a CoreS3 with a COM.NB-IoT. Somehow I can;t get the SIM7020 get to work. Does someone have a example code? I have changed the dipswitches to:
      #define SerialAT Serial1
      #define MODEM_TX 13
      #define MODEM_RX 7
      From the IoT_BASE_SIM7020 I have extracted the TinyGSM code for the SIM7020. But as mentioned, I can not get it to work. Does someone have a full working example? I do have the COMMU module on Serial2 on:
      #define Serial485 Serial2
      #define RS485_TX 17
      #define RS485_RX 18
      TinyGsm modem(SerialAT,0);
      void setupModem() {
        pinMode(2, OUTPUT);
        digitalWrite(2, 0);
        SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
        TinyGsmAutoBaud(SerialAT, GSM_AUTOBAUD_MIN, GSM_AUTOBAUD_MAX);
        modem.init(); // Not working
        String modemInfo = modem.getModemName();
        CoreS3.Display.printf("Modem Name: %s\n", modemInfo);
        Serial.print("Modem Name: ");
        Serial.println(modemInfo);
      • felmueF Online
        Hello @markpro
        GPIO13 in M5CoreS3 is already used by the speaker amp. So it probably can't be used for serial. See schematic here.
        BTW: you don't need to set GPIO2 as output and set it to LOW as GPIO2 is not connected / used by the COM.NB-IoT module. See schematic here.
          markpro @felmue
          @felmue Thanks, after reviewing the docs I also made a mistake in the Pins. Adjusted to below and now I get a reponse of 1 on modem.test(). So looks like I have it connected :)
          #define MODEM_TX 7
          #define MODEM_RX 1
          • felmueF Online
            Hello @markpro
            glad to hear you got it working.
            BTW: GPIO1 is already used on port A (I2C). But that is fine as long as you do not need external I2C as well.
