    M5 Flow2 + Web Server
    1 Posts 1 Posters 1.8k Views 2 Watching
      makazmie
      I am trying to have two parallel capabilities:
      • UI functionality (with BtnA.setCallbacks, etc.),
      • WebServer (to listen on specific port and change UI labels based on received data).
      When I use the following code:
      if __name__ == '__main__':
        try:
          setup()
          addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
          s = socket.socket()
          s.bind(addr)
          s.listen(1)
      while True:
        M5.update()
        conn, addr = s.accept()
        print('client connected from', addr)
      Then UI stops working (as probably code hangs on socket accept). As soon as I comment: s.accept, then UI starts working again. What is interesting is that socket also does not work as well.
      Can you advise how to enable these two capabilities at the same time?
      Thanks!
