    Is Relay Unit programming broken
    4 Posts 2 Posters 2.9k Views
      Kombistack
      Stupid question! I have been trying to get my relay units working on UIFLow 2 with an AtomS3Lite and on UIFLow 1 with a Stamp Pico. I've resorted to very basic programming to turn the relay unit on and off once every 5 seconds and they are not working. I have used these M5stack relay units only last week and they were both working fine.
      I'm just wondering if something is broken in both versions of UIFLow??
        Kombistack
        This is the simple program
        This is the terminal response.
        Does this indicate a problem with the Relay Unit programming in UIFlow?
          By default the port is set as a digital/I2CPort and so normally a relay unit wouldn't work.
          Oh BTW the default Port is A not B, the terminal says you set it to port B which doesn't exist on the Atom and stamp.
            Kombistack
            Thanks ajb2k3,
            I did manage to get my Stamp Pico working with both a PIR sensor and relay unit.
            The problem was my fault. In soldering on the grove connector to the Stamp Pico, I soldered it on the wrong side of the board so when I connected a grove cable - ground was connected to GPIO 33, 5v was connected to GPIO 32, GPIO 32 was connected to 5v and GPIO 33 was connected to ground. Fortunately I didn't cook my board.
