    UIFlow 2.0.1 HTTP GET and parse JSON
    3 Posts 2 Posters 2.8k Views
      streammyevent
      Hi team,
      I'm trying to complete the simplest of all possible projects, and for the life of me after two days of troubleshooting I simply can't figure it out.
      Device: Core2
      OS: Mac OS 14.2.1
      Software: UIFlow v2.0.1
      I'm trying to HTTP GET a local JSON endpoint with some data.
      I started off trying to program this with the visual interface, but found that I quickly had to switch to python because of the missing 'urequests' lib (there's another thread about that on this forum).
      Using the 'requests' library, I found that I can perform the GET request and actually get a 200 status OK back. However, when using the response.json() call, the program hangs with no error and no output.
      If I run the same requests in python3 on my desktop environment, it all works.
      Here's where I got to:
      import os, sys, io
      import M5
      from M5 import *
      import network
      import requests
      title0 = None
      statTitle = None
      resTitle = None
      stat = None
      res = None
      # http_req = None
      wlan = None
      status = None
      def setup():
        global title0, statTitle, resTitle, stat, res, http_req, wlan, status
        M5.begin()
        Widgets.fillScreen(0x222222)
        title0 = Widgets.Title("Powermonitor", 3, 0xffffff, 0x0000FF, Widgets.FONTS.DejaVu18)
        statTitle = Widgets.Label("Status:", 2, 28, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        resTitle = Widgets.Label("Response:", 2, 57, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        stat = Widgets.Label("...", 110, 29, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        res = Widgets.Label("...", 111, 57, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        stat.setText(str('Fetching'))
        http_req = requests.get('http://192.168.10.22/api/v1/data')
        status = http_req.status_code
        stat.setText(str(status))
        print(str(http_req.status_code))
        print(str(http_req.reason))
        print(str(http_req.encoding))
        # print(str(http_req.raw))
        # print(str(http_req.text()))
        data = http_req.json()
        print(str(data))
        # print(str(http_req.json()))
        # http_req.close()
        # print(dir(responseJson))
        # print(responseJson())
        # res.setText(str(http_req.json()))
      def loop():
        M5.update()
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
            print("please update to latest firmware")```
        Are you sure its hanging and not taking ages to get a response?
          streammyevent
          Yes, the endpoint responds almost instantly. Also the status code immediately comes back as as '200'.
