    M5capsule UIflow 2 neopixel
    Cores
    2.6k
    • J
      jgude
      Hi!
      I just starting with a M5capsule and a neopixel sk6812 led strip and i want to make a music activated lgiht show on it, but im already stuck in the basics.
      In UI flow 2 (which i need for the m5capsule) i cannot find a good rgb unit like in ui flow 1. There is a rgb unit, but it doesnt give the neopixel options like in ui flow 1. How can i add this?
      Second basc issue. in the build-in hardware list there is no microphone listed, but it should be there right?
        If you understand Micropython then the RGB functions are available, but untill M5Stack add the RGB strip unit into UIFlow2 there is no function
