    M5stickc plus2 and Tft_espi problem.
    13 Posts 2 Posters 9.4k Views
      Kazik
      Hi
      I was trying to compile esp32 marauder for m5stickc plus2 but I have problem with lcd. It stays black. Fw seems to work because cli works. I changed pins and driver for ST7789_2 in User_Setup.h for Plus2 and nothing. For esp32 marauder you have to use old tft_espi lib (2.3.70) to proper compilation process. Maybe someone used tft_espi lib with plus2? There is compiled fw for plus (not plus2). So I suppose for Plus2 it is possible too.
      • felmueF Online
        Hello @Kazik
        the LCD backlight is probably missing. It's controlled via GPIO27 driving VLED. See schematic. Also in the GFX library GPIO27 is setup as PWM backlight. See here.
          Kazik @felmue
          @felmue said in M5stickc plus2 and Tft_espi problem.:
          Hello @Kazik
          Thank You very much it helped. But now i must be connected over usb to show something on screen. Without usb screen blinks for sec and black. And navigation over menu is very poor
          • felmueF Online
            Hello @Kazik
            please read the yellow note from the documentation.
            After triggering the wake up signal, the hold(G4) pin needs to be set to a high level (1) in program initialization to maintain the power supply, otherwise the device will enter the shutdown state again.
              Kazik @felmue
              Hello @Kazik
              I dont know where to put this in marauder code. I need advice. I managed to compile the code to work on plus 2. only works if the usb cable is connected. Marauder code is very problematic for M5Stickc.
              • felmueF Online
                Hello @Kazik
                you'd put that at the beginning of setup().
                  Kazik @felmue
                  @felmue just simple like this?
                  // Set digital pin 4 (GPIO4) to high state
                  pinMode(4, OUTPUT);
                  digitalWrite(4, HIGH);
                  • felmueF Online
                    Hello @Kazik
                    yes, that should do it.
                      Kazik @felmue
                      Nothing changed :( i have no clue what is wrong.
                      EDIT Now its working Thank You very much
                        Kazik @felmue
                        @felmue hellol could you tell me is pins to connect sd card module to plus2 are the same as plus?
                        3V3 > 3V3
                        CS > GND
                        MOSI > G26
                        CLK > G0
                        MISO > G36
                        GND > GND.
                        Of course I must change pins in source code.
                        • felmueF Online
                          Hello @Kazik
                          from what I can tell looking at the documentation for the two M5Sticks here and here I would say the same GPIOs can be used for both.
                          Please note: I do not have an M5StickCPlus2 so I cannot test this myself.
                            Kazik @felmue
                            @felmue So I source code I must change CS pin to LOW? To match for GND?
                            • felmueF Online
                              Hello @Kazik
                              SPI bus can handle multiple (slave) devices. Each has its own CS. See here.
                              That said, if the SD card it the only slave device it's ok to connect its CS directly to GND. If you want to use a GPIO for CS then yes, set it to LOW.
