Help with ESP-Now and UiFlow on M5Stick C?
Hello! I'm wondering if someone might be able to help me with the UiFlow ESP-Now examples?
When I try to run the default Master & Slave examples I get this error: "name 'label1' isn't defined"
I tried a bunch of different things but for some reason I can't get this to work.Note: I'm currently using UiFlow version V1.12.8 as it seemed to have the most support for the ESP-Now modules.
Any input would be much appreciated! -S
Hi @sodar,
Because all examples are designed for "core-basic" (device name), not stickc or other core devices (core2, fire, etc...), So you first understand the example logic and create (stickc) ui blocks that are relevant to your device.Like this:
Hi @pandian-nano, Thanks! That was super helpful!
That took care of the problem but now I'm getting the following error: "name 'now' isn't defined'
Trying to figure out what's going on... it would be so fun to use ESP-Now on this thing :]
I know I could probably use the arduino ide to do this, but I was just starting to get excited about UIFlow, it's pretty neat!
