    Cardputer & Sensors
    5 Posts 2 Posters 6.7k Views 2 Watching
    • B Offline
      Bipman
      Hi all
      Not sure if this is the correct forum but I have had my Cardputer delivered and wondered if I could use my Core2 and 3 sensors with it? It doesn't seem to have a Port A,B etc.
      Steve
      • felmueF Online
        Hello @Bipman
        the Cardputer does have a Port A on the side like most cores. See documentation here.
        • B Offline
          Bipman
          Hi
          Some sensors only use port B,C etc. so not sure how I would connect those.
          Steve
          • felmueF Online
            Hello @Bipman
            by default Port A is meant for I2C, but it can be used for I/O (Port B) or UART (Port C) as well.
            Note: But please be aware, that it can be only one type of port at any given time. Also, since its default use is Port A (I2C) there are internal pull-up resistors (10 k) in place on both lines which might have a negative effect when used in a different mode.
            If you need Port A and Port B at the same time there is the PbHUB unit which can be used to connect some of the Port B units.
            If you need all three types of ports (A, B and C) together then I am afraid M5Cardputer is the wrong device to use as core. There are simply no more GPIOs available for a dedicated Port B and/or Port C. Please see schematic here.
            • B Offline
              Bipman
              Thanks for the replies everyone.
