    Pb.HUB will not connect. [Fixed]
    18 Posts 3 Posters 16.2k Views 1 Watching
      Ahh power draw issues.
      Try providing separate power to the devices but only connect the signal and GND pins to the PbHub.
      I 2 Replies Last reply Reply Quote 0
      • I Offline
        IsoEek @ajb2k3
        @ajb2k3 I have a few Type C 2 Grove. I cant believe I didnt think about that. Thank you. I'll let you know how it goes.
        • I Offline
          IsoEek @ajb2k3
          @ajb2k3 Still no joy. 🤔This is from the terminal.
          ets Jun 8 2016 00:22:57
          rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
          configsip: 188777542, SPIWP:0xee
          mode:DIO, clock div:1
          load:0x3fff0018,len:4
          load:0x3fff001c,len:5228
          load:0x40078000,len:12908
          ho 0 tail 12 room 4
          load:0x40080400,len:3512
          entry 0x4008063c
             _  __ _
          _ ()/ | | _____ __
          | |/ _ \ \ /\ / /
          | || | | | | () \ V V /
          _
          ,||| ||___/ _/_/
          APIKEY: A2DCA138
          File "flow/m5cloud.py", line 82, in _exec_fun
          File "<string>", line 9, in <module>
          File "unit.py", line 186, in get
          File "<string>", line 1, in <module>
          File "units/_pbhub.py", line 15, in init
          File "units/_pbhub.py", line 21, in _available
          Unit: Pb.hub unit maybe not connect
          1_1692054157240_uiflow_block_PB_Hub_Atom.png 0_1692054157240_Atom Pb Hub Wiring sm.png
          • I Offline
            IsoEek
            I can't connect PbHUB V1.1 to Atom Lite or Tough.
              pandian.nano
              First check if pbhub is connected or not? Check whether the i2c scan device result is [0x61] or [97].
              I 1 Reply Last reply Reply Quote 1
              • I Offline
                IsoEek @pandian.nano
                @pandian-nano Thanks for the suggestion and help. This is what is in the terminal.
                === from m5stack import *
                === from m5stack_ui import *
                === from uiflow import *
                === import i2c_bus
                === import time
                === import unit
                === screen = M5Screen()
                === screen.clean_screen()
                === screen.set_screen_bg_color(0xFFFFFF)
                === pbhub_0 = unit.get(unit.PBHUB, unit.PORTA)
                === i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x00, freq=400000)
                === i2c0.addr=(0x68)
                === while True:
                === print(i2c0.scan())
                === wait_ms(200)
                === wait_ms(2)
                File "<stdin>", line 10, in <module>
                File "unit.py", line 190, in get
                • I Offline
                  IsoEek
                  I have lost track of how many times ive erased and downloaded the firmware. This is the last Terminal screen.
                  Connected to Serial Port!
                  ( �m�!0ϟ��( �m�!0���
                  _ __ _
                  _ ()/ | | _____ __
                  | |/ _ \ \ /\ / /
                  | || | | | | () \ V V /
                  _
                  ,||| ||___/ _/_/
                  APIKEY: 2F9D3FE8
                  File "main.py", line 12, in <module>
                  MicroPython b0cb55176-dirty on 2023-08-03; M5Stack with ESP32
                  I felt I was making decent progress at first. I have had so many failures now, I question the little bit I do know. Tried Uiflow V2 but Pb.Hub is not available.
                    pandian.nano
                    0_1692167268589_7e4f250d-e7a6-4a0f-87f9-fff2bafa0fd7-a90fa071078c2fe2db6a48d44bc9637.jpg
                    Please check again and check the result
                    • I Offline
                      @pandian-nano Thanks. This is the out come. I looked up the Hex for 96 and I get 0x60. I believe I need to set init and/or set the new address. Is the answer as simple as using the Write Memory Data under I2C Master? Is the included block what I need to burn? I'm doing my best to learn this, but damn there is a lot to learn!
                      I tried using this code and I had no change.
                        pandian.nano
                        @IsoEek
                        • Please check again and check the result 0x61[97]
                        • If you get 0x61 result then your pbhub i2c address was changed from 0x60 to 0x61
                        • I Offline
                          @pandian-nano said in Pb.HUB will not connect.:
                          97
                          I now get [97] and True. I just tried using digital and analog read. Both are working as expected. That was a really cool party trick! Where can I read more about what you walked me through. I obviously have no issues making bad code. I need to know how to clean up my own messes and how to debug. Thank you so much for the help. I appreciate it more than you know.
                            pandian.nano
                            @IsoEek https://docs.m5stack.com/en/quick_start/m5core/uiflow
                            • I Offline
                              @pandian-nano Thank you. I have read through that several times and it makes no more sense than the time before. I'll eventually come across something that I understand and it will sink in. Thanks again.
